DrSheep
- Nov 17, 2012
i will skip the tabasco sauce and go straight for the red carolina reaper pepper. over 2.2 scoville heat units.
I think you meant 2.2 million .
hey mr gavin, did you order that double quarter pounder without red cheese enchiladas and the cheese burger with red cheese enchiladas? both looks tastefully enticing.
Question: Hopefully will A/B the 380 to my 240, tomorrow. You folks who have thoroughly A/B both, what 2 songs would you suggest I use as a test?
Aloha
EASY......Your favorite 2 songs
Will it be the stock 380 or the Copper one?
Duh.......lol yes will choose 2 of my favs. Hey Gavin, long time no speak, thanks for the answer. I'll try both models if they have.
Yup been a while, my friend!!!
Irrespective, if you do like the Stock 380 over your 240, then hunt the Cu down if possible.
The effortless and non fatiguing presentation of the Cu is highly addictive............and of course then the Cu amp
Highly recommended!!!
Mmm......I am trying to figure out what the best way to STORE the AK 380 cu that would minimize oxidization. I regularly cycle several DAPs. Even untouched, the oxidization process continues. I've tried storing it in a Pelican, with moisture absorbent packets. It works reasonably well in retarding the process of oxidization ( or tarnishing) while in storage. But not good enough. I will try storing it in a vacuum-sealed container. With no oxygen, I figure the tarnishing will be very minimal (oxygen + moisture = tarnishing of copper).
If I had to polish my DAP on a regular basis, I wouldn't consider it the best in the world.
Don't start collecting watches yet...
