- Apr 16, 2016
Don't think so, are there any AK reps here and if not does anyone know a reliable way to contact they're support? I'm so pissed right now
yes I did a settings reset but it wouldn't do anything, now I confirm it plays 3.5 when out of the amp's 3.5, but as soon as I switch off the amp and use the DAP the BAL indicator instantly returns and does not go away
Maybe this could solve your problem; try to install the older firmware and re-install the new firmware again, I hope you get it working correctly.
The problem is that you can't flash the firmware to an older version without sending it back to AK, since the update is automatic.
Mine is also stuck in bal mode! what the hell!?!
How do I fix it
seriously, it was fine yesteday, all of a sudden start it up and it's stuck in bal!
reformated it and it's still stuck,
did you find a fix? Just contacted Jimmy Moon from AK and waiting for a response....
Mmm.....perhaps AK, in the next firmware update, can reinstate the Bal icon under settings. I experienced the same stuck Bal mode problem with my cu before. The problem was resolved with a simple restart. Also, I inserted different in-ears with 3.5 mm plug and I made sure that the plugs were spotlessly clean. It could be a contact problem.
factory reset erases all data and settings, I believe all songs in internal memory will be wiped, I'm not going through the trouble of having to put back all my music into the thing if this happens to be just a firmware glitch that can fixed by OTAIt's been a while, but isn't there a factory reset option? I don't believe resetting settings to default is the same, but I don't remember on my AK models.
How long ago were you stuck and were you on firmware 1.24? I restarted no less than 5 times and also clicked on 'Default Settings - Settings reset' twice now, I have also plugged in four 3.5mm iems, and a 2.5mm > 3.5mm converter jack, my 380 is still stuck on 'BAL' perpetually. I have 'blown' some wind into the port to get dust away, and the 3.5mm port works for optical out so it should be a contact issue or dirt problem after all. Still waiting for iriver's response ... lucky for you to have resolved it without having to send it in or via some firmware change
It is official. AK380 Cu is the best DAP ever made. It is astounding how iRiver can design products so similar in everything yet one is significantly better than the other (i.e. Cu over the original 380). Kudos, iRiver.
Wait until the next it will be released, and then i will see tears ( but not of joy ).
