I spoke with Vinnie from Red Wine Audio and below everything I could gather...
RWAK380 modification will be available by the end of this month. Similar to the RWAK240. Specifically:
- Adding more capacitance > 2,000uF of low ESR capacitance - this really improves dynamics, punch, speed, bass quality (tightness, definition) ... just like you get with a good quality external headphone amp.
- Utilizing bypass caps in certain locations to open up the top end some more. Not to make it brighter... just to get a little more sense of space in the recordings that is missing compared to other stand-alone amps., and to get a little more decay and low level detail.
This modification will be a nice improvement no matter if you use IEMs or full size cans.
However to get the most out of harder to drive headphones like the HE1000s, LC2/3's (and potentially the LCD-4), HD800, etc. more power is needed.
Therefore Vinnie is looking into two other options. However it’s not finalized yet!
The two options maybe:
- RWAK380H modification. (H for high output power). RWAK380H would add a dedicated balanced output stage to the RWAK380 that would actually be installed *inside* the AK380 and has will have the power of a very strong desktop amp! Powerful enough to drive HE-6s. It would replace the stock balanced output of the AK380 (but the SE would remain the same as the RWAK380). It's still a Class AB output stage (not Class D), but a lot more output power and still fit inside your pocket.
Of course those who don't need the extra power would not need the RWAK380H mod.
The second option maybe:
- Look into AK380 external amp and decide if it makes sense to mod it
Vinnie is hopeful there will be more room inside (the amp) and perhaps he could install his custom balanced output stage inside. He is weighing decisions with regard to power draw and potential reduction in play time (of the AK380 DAP) by an hour or two if one is playing music loud into harder to drive cans. As more output power = more current draw from the battery.
Your feedback to Vinnie is very much appreciated as he continues working on RWAK380H mod (to either be used inside AK380 DAP, or inside AK380 external amp instead. As he put it to me: “The RWAK380H would definitely be the most powerful DAP available... and for those with cans that need the power, it will blow your mind, baby
Sincerely,
Your friend in audio.
-Speed
