Astell&Kern A&ultima SP3000
Feb 29, 2024 at 6:18 PM Post #3,737 of 5,542
Is this since the last firmware update?
It worsened but stanby time has always been VERY underwhelming.
My HiBy RS8 can be in standby -ready to go- for TWO WEEKS
Mar 1, 2024 at 12:23 AM Post #3,739 of 5,542
I don't have an SP3000 but an SR35. I've found to keep the battery from draining I turn off both my wifi and my bluetooth every time I turn it off.
Me too. Underwhelming regardless.
Mar 1, 2024 at 10:21 AM Post #3,741 of 5,542
When you say standby, do you mean you just put the player into sleep and don't turn it off, or you turn it off and still see battery drain?
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Mar 1, 2024 at 11:43 AM Post #3,742 of 5,542
Sleep
Mar 1, 2024 at 3:55 PM Post #3,744 of 5,542
I don’t see much drain when my SP3K idles usually but I haven’t checked with the latest FW, yet.
Is it possible that it drains more when a headphone is plugged in while idle?
Mar 1, 2024 at 11:28 PM Post #3,745 of 5,542
This is 904L stainless and ie600 and It’s incredible !
Mar 2, 2024 at 4:26 AM Post #3,746 of 5,542
The best player i have heard and the more i ear other players more i am sure
Mar 2, 2024 at 8:02 AM Post #3,747 of 5,542
Mar 2, 2024 at 8:04 AM Post #3,748 of 5,542
Do you have Roon Ready turned on? If so, any Roon Ready device polls the network at set intervals to alert Roon Core that there is a Roon Ready device available and waiting for playback.
Everything turned off mate. Still the battery drains at 8-10% per hour in standby
With EVERYTHING ON my rs8 lasts for a couple of weeks in standby 🤦🏼‍♂️
Mar 2, 2024 at 8:30 AM Post #3,749 of 5,542
What is your take on the SP3000 and your experience with the NE30? Will you keep both, do you have different use cases?
Both are DAPs that I love . The N30LE has the advantage of having tube amplification (Classic and modern) which for me is a must.
The N30LE I only use it at home, often also with my Amp Aroma A100TB (incredible synergy with the N30LE in Classic tube mode), while the SP3000 I use it when I'm out
Mar 6, 2024 at 7:30 PM Post #3,750 of 5,542
There's an issue with the latest Roon Arc APK update. The login page continously loads to no avail 🙄. Also, offline imports in Qobuz are failing when trying to play (Unable to play this track offline) and then deletes the track automatically. Any help would be appreciated!
