Astell&Kern A&ultima SP3000
Mar 6, 2024 at 7:36 PM Post #3,751 of 5,581
There's an issue with the latest Roon Arc APK update. The login page continously loads to no avail 🙄. Also, offline imports in Qobuz are failing when trying to play (Unable to play this track offline) and then deletes the track automatically. Any help would be appreciated!
Happens to me almost daily on my Samsung Android phone with the Roon Arc app.
What is the version that you are using? I assume the one on the download tab in the Services menu.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Mar 6, 2024 at 7:45 PM Post #3,752 of 5,581
The built-in version works great. It's the newest APK file from Roon's website. Are updated versions not supported?
Mar 6, 2024 at 7:55 PM Post #3,753 of 5,581
There ahoukd be no issue with updated versions. I will download it romorrow and test on the SP3000 I have here and on my phone.
Mar 7, 2024 at 7:16 AM Post #3,755 of 5,581
Issue with ARC is all time... I give up and buy UAPP.
Mar 7, 2024 at 9:50 AM Post #3,757 of 5,581
It works for me using a rock. The updated version uses a web page for login, which never seems to work with A&K...
Mar 7, 2024 at 12:25 PM Post #3,758 of 5,581
The new version that you are trying to use is 1.0.46, correct?
It will not connect on my Samsung S23 Ultra. Just get the spinning "it's taking longer than usual to connect." On the SP3000, was able to get in and play music right away with v 1.0.40. Will try to install the latest from Roon's site, which I believe is 1.0.46.
Mar 7, 2024 at 1:21 PM Post #3,759 of 5,581
Yeah 1.0.46 takes you take a web page for login and continiously displays a loading wheel.
Mar 7, 2024 at 1:26 PM Post #3,761 of 5,581
Yep, same thing I get on my android phone
Have you ever had issues with offline play using the Qobuz app? My imported files always say 'can not play track offline' and then are auto deleted. Not sure what might be the issue..
Mar 7, 2024 at 1:53 PM Post #3,762 of 5,581
I use Qobuz and I also have over 100 downloaded albums that I listen to offline. Everything is ok, no problem. I always keep Qobuz updated
Mar 7, 2024 at 2:17 PM Post #3,764 of 5,581
I'll have to delete and try the updated version. Thanks!
Mar 13, 2024 at 2:43 PM Post #3,765 of 5,581
904L SS with Campfire Audio Stella Horizon
