rlw6534
To be clear, you have to use an older version of Amazon Music (newer versions require Android 7). Apple Music still supports Android 6.
The latest version of Amazon Music that works is 22.15.13
OMG, what a shame to AK, this continue fro AK380, what a trash support, what a trash service, glad that I decided to end it up with AK.Question for JasonNYC
Sponsor: Astell&Kern
I have a problem with Astell&Kern A&futura SE200.
Sometimes even three times a day when I start PLAY, the music does not go to the headphones (but time flies).
Sometimes playing a different track from a different album helps, other times I have to turn the SE200 off and on.
I already had the SE200 serviced in Germany, but they didn't fix the fault.
They claimed to have replaced the CPU and LCD display.
I would like to ask. Is it possible for me to flash the firmware myself?
Where can it be downloaded?
Thanks a lot for your reply.
Have exactly the similar issue recently. especially when Im trying to compare few headphones. And for me changing the ports helps. I suggest its the fault of last updateQuestion for JasonNYC
Hi.Have exactly the similar issue recently. especially when Im trying to compare few headphones. And for me changing the ports helps. I suggest its the fault of last update
Привет.
После смены наушников и подключения к тому же порту иногда музыка в них просто не играет, типа нет сигнала, но на экране отображается как "играет" и например меняя с сабрами на АКМ, у меня снова звук в наушниках.
Hello!Question for JasonNYC
So what does your message imply?Hello!
Unfortunately, this problem cannot be fixed in the service centers. I think so.
I had two se200 players.
One has this problem, the other doesn't.
Stand up firmware
whether the same.
Well, one used player, the second was new.
I think it shows up over time.So what does your message imply?
I have last version of firmware (1.40cm).
