lawshredpower
Hi, excuse me. About details, soundstage, instrumental separation, imaging, and timbre, between sp1000 and se200 which is better in each thing?
Using for example only iems or low impedance headphones.
SE200
Why bro? I have sp1000cu but i do not have problem to buy se200 if it has more soundstage and details. But i would like to know if it is worth the investment. I only use iems with sp1000 because I use my big headphones with other daps, portable amps and desktop.sp1000 without hesitation
Then, se200 is more transparent than sp1000 but it has less technical capabilities vs sp1000? Is very difficult for me try to understad the conclusion of your coment bro. Could you explain me please?In my personal experience, the SP1000 and SP2000 both had a very balanced tuning with wide soundstage. The SP2000 was a bit more transparent than the SP1000 in that you could hear micro details a bit better, neither had bass or treble that was too much.
The AKM side on the SE200 sound like the SP2000 but just tiny bit forward on the lows I beleive. But it does sound quite nice and I'm really enjoying the player.
Agree. My hd800 sound similar in bass impact and dynamisn by 3.5mm of sp1000 with only 2 volts vs dx220, little bear b4x and hiby r6pro with almost double or numbers hahaahaha. Buuut flamenco (with rapid frequency transitions) loose dynamic range in highs. (Not mentioned powerfull daps)The specs, for a couple of bucks (as in this case), don't always tell the whole story
That is the reason why i am asking what your ears say... in astell and kern the numbers are just numbers. In an amp implementation, other things take more importance than a simple RMS messure. The impulse response to check control in gain and phase under heavy loads tell me more than rms output level. BUT a listen test tell even more than messures. Anyway, i am still waiting for more perceptions about the sound of se200 vs sp1000.
Sorry, no, I did not. Now, after read both post, I can conclude that you say. Se200 akm side is v shaped sp1000. Thanks a lot of. Then, i think, ess is almost the sale but with other timbre.... thank you so muchDid you read my post earlier?
Basically to my ears, the SE200 sounds like a slightly more v shaped SP1000.
Yeah, the ESS side is also interesting as the ESS is pretty balanced with a lower dB, I find that you can "dynamically" increase the sound dynamics bit raising the volume for a much fuller sound. Still if you want the more engaging sound signature, AKM chip is the way to go.
