carlchip78
- Nov 27, 2011
don't get dragged into a debate about "there can be an audible difference" vs "there can't be an audible difference". that's a strawman argument, not the topic. of course there can be a difference, a defective cable being the most obvious example but not the only one. we all accept the possibility of an audible difference, that's what being open minded really means. but in this sub section going from being open to the possibility straight to claiming it's a fact, that requires those little things called proof.
real life analogy born to fail:
if I post like R Kelly that " I believe I can fly, I believe I can touch the sky", what I'm really saying is that I believe in something, I didn't claim I could actually do it, only that I believe I can. that's what we call an opinion.
now if I say "I can fly, and I've touched the sky many times, you only need real good shoes, special shoelaces and good toes", most people would be like: ".AVI or it didn't happen". and of course you would be justified to ask for evidence because I'm no longer saying I believe in something, I'm claiming it happened for a fact.
facts require evidence.
if you don't have evidence, you cannot prove something to others, therefore you should stick to cautiously expressing your opinion on the matter.
QED.
Hear hear.. always the voice of reason.. Seems like you're one of the good guys. I have no background surrounding your avatar, but it does seem fitting after reading a lot of your "everybody, calm down now" posts.
It's easy to become closed minded on a topic regardless of which end of the "Sceptic > Believer" scale that one falls into. I get that.
