- Jan 30, 2011
And again - you go toward your circular debate - which is a real pity. Whether this is intentional or not does not matter - it is happening. Avoidance still gives the same result.
So at this point I will simply unsubscribe. There is little point me being here. If you are unwilling or unable to follow up your theory with meaningful data, then I would suggest all people on this thread do the same. It would then make my job as a Moderator much easier too.
