my shure headphones sound better then my 100$ logitech speakers but is it a general rule that speakers are cheaper or more expensive.
whats the better value for the money.
It depends on how lucky you are. It's easy to get a set of planars or great vintage speakers for the price of mid-fi headphones, if you're willing to wait. People tend to overlook the older/diy stuff in place of the new, shiny, expensive stuff. Strike me down if I ever find a pair of headphones that beat a pair of vintage AMT speakers, Maggies, or if you're especially lucky, Carver ribbons for the same price ($300-400ish) they tend to go for locally.
If it's quasi-ribbon speakers you're looking to compare to, even lower cost headphones tend to have substantially lower distortion which is worth noting. Generally to get speakers with similar performance of headphones technically you're looking at something like a used pair of Martin Logans (stats, not ribbon or primarily cone based). Not sure how true ribbons compare though, so maybe true ribbon Maggies could also be considered. Either way if I'm not mistaken you're still looking at around ~1K used excluding amplifier (which take more grunt to work with a capacitive or extremely low near purely resistive load).
Basically, it's not nearly as expensive getting a really good performing headphone new in comparison.
