#share impression / mini review of Aune AR5000
For the specs skip it, just googling
But clearly the driver is Dynamic type, 28 ohm impedence with Sensitivity 108dB, YES! Easy To Drive.
Build Quality Feels solid, metal material not Plastic, Design is also good-looking, with a pink grail filter, unique!
The fittings for my head personally feel very comfortable, the headphones are light, the clamping is not too strong, the pads are also soft but not too soft, listening for quite a long time changing head sources don't complain of pain, also not hot in the ear area ...
For Sound Quality I used 3 devices:
● Fiio Q15
● iBasso DC06 Pro
● And Fiio Q11
But mainly and what I will explain is the impression of using Fiio Q15, but still later I will give a comparison of the impression with 2 other dac amps.
The Aune AR5000's Sound Signature is neutral to warm with highs that are quite energetic and have spark, so it sounds textured, thankfully not very extended highs. For the timbre, the Aune AR5000 also sounds very natural, the high colloration still sounds natural even though it's energetic.
The highs in quantity are typical of neutrals, in quality they are smooth and airy, the texture can be heard without feeling grainy.
Neutral mids are quite thick, not really thick, not really warm, just right, vocals feel solidly focused, it's really good to hear vocals in these headphones, besides that the sound of instruments also sounds natural.
For the bass, it's really the typical bass that I really like, agile and detailed, not boomy but very clear every bass sound, in quantity it's at a neutral level, not big but also not lacking.
In the technicality that feels special in terms of separation, really clear between the instrument sounds, well separated, clear pin point location of the instrument / each sound, the depth is also fairly good, feels spacious, only if the width of the soundstage is not very wide, but also not narrow, the comparison compared to the HD600 feels wider this AR5000. The micro detail is also good, the small details sound quite solid.
● Listening to ibasso DC06 pro compared to Q15, the technicality is significantly different, not as "Spacious" as Q15, the sound signature also sounds significantly warmer and the bass increases slightly.
● Listening to the Q11 compared to the Q15, the technicality has also decreased but still feels a little spacious, still feels the depth imaging, the sound signature is a little warmer, tonally I actually like the tonal when plugged into this Q11, if this sound with the technicality of the Q15 is really good.
This short impression was written using a unit from Beyond The Music (BTM), one of the high end audio stores in Indonesia.
So I personally hope to win one of them to be my personal main headphone.
Always success for
@AuneAudio . I hope aune makes headphones like this again but with a more affordable price. Thank you
