Dec 14, 2022 at 1:36 PM Post #691 of 3,450
I've got a Strike 4 now... just tried it on my PC and the USB interface is disconnecting and reconnecting randomly making it completely unusable. Defo not a normal unit. The seller is asking me troubleshooting steps, I've already said in previous messages that I've tried and didn't work.
Hi, can I ask is there a TLDR version of your experience with Bluetooth transmitters? Like I am looking for a transmitter that supports Bluetooth 5.2 and Aptx-adaptive to connect my TWS to my PC. I found BTD 600 and Creative BT-W4 but Idk which is better or are there other choices in the markets?
Dec 14, 2022 at 1:44 PM Post #692 of 3,450
Actually i returned the BTD600 to Sennhieser due to drop outs to MOMENTEM 4. It did show AptX Adaptive in the Senn iOS App - which is good.
Disappointing that the colour led doesn’t indicate specifically Apt X Adaptive.
My BTW4 is arriving today. Got it directly from Creative online store who have a discount right now.
https://uk.creative.com/p/accessories/creative-bt-w4#download
Hi, just wanna ask how's your experience with BTW4, coz I am also looking for a transmitter for my TWS and struggling between BTD600/BTW4.
Dec 14, 2022 at 2:12 PM Post #693 of 3,450
My favourite [for now] is the KB9P. it’s so cheap, you can buy it and then buy another if you don’t like it After all.
Dec 14, 2022 at 2:26 PM Post #694 of 3,450
Have you considered using the alternative a2dp driver on windows? It makes aptx adaptive obsolete for pc use imo.
You can bump SBC bitrate with it, 550-600kbps works with everything i tried, some devices might be able to do more. You can use basically any regular BT dongle with it, or built in BT if youre on a laptop or if your desktop has one.
Dec 14, 2022 at 2:53 PM Post #695 of 3,450
Hi, thx for the recommendation but I never heard of that a2dp thing. Where can I buy it or which brands product that? And I dont have a BT dongle for my PC now so I am looking to buy one for my new TWS
Dec 14, 2022 at 3:05 PM Post #697 of 3,450
Dec 14, 2022 at 3:13 PM Post #698 of 3,450
Its just a alternative BT driver for Windows 10/11, it can be used with practically any BT dongle. I use a $3 BT 4.0 one(CSR8510 chip), Orico BTA-403 model.
https://www.bluetoothgoodies.com/a2dp/
Edit:
BTW, as a bonus it also adds LDAC support to Win 10/11.
Dec 14, 2022 at 3:17 PM Post #699 of 3,450
https://www.aliexpress.com/item/1005004573659715.html This link drops you to the first product on this page. You have a selection to choose from and we recommend picking one of the 24-bit ones.
if it’s for PC, you might want one with an antenna on it:https://www.aliexpress.com/item/1005004573760966.html
Thx alot! Does it indicate which specific codec is in use? And why would you choose KB9P as your fav? For example, maybe because its stability or lowest latency among other dongles?
Dec 14, 2022 at 3:20 PM Post #700 of 3,450
Codec indicated by LED colour on the KB9P. It has been stable and has adjustable codec controls via PC app.
I haven’t confirmed latency as I use these for highest quality music playback.
Dec 14, 2022 at 3:21 PM Post #701 of 3,450
I just found something on Amazon looks exactly the same as your 2nd link. https://www.amazon.co.uk/gp/product/B085RK1VWS/ref=ox_sc_saved_image_2?smid=AZ1726BUZXKIV&psc=1
But it seems another brand.
Dec 14, 2022 at 3:23 PM Post #702 of 3,450
Edit:
Oh its a driver. Ok I will install it see what happens with my TWS. But now I will have to wait for my dongle to test coz my PC doesnt have Bluetooth default on motherboard.
Dec 14, 2022 at 3:27 PM Post #703 of 3,450
I saw it that you also have the Nura Bluetooth 5.3 USB-C adapter, hows that one compare to the KB9P? Because it takes 3 weeks for KB9P to deliver to UK and Nura is much faster.
Dec 14, 2022 at 3:30 PM Post #704 of 3,450
Just mind you, this will work with standard bt dongles, ones that you can also connect peripherals to. Will not work with dongles like KB9P that @mcnaugha sent you a link to or the amazon one you linked, those are audio only and are detected as a sound card by the OS.
Dec 14, 2022 at 3:32 PM Post #705 of 3,450
