Sony Inzone Buds mini-review.
Finally....
finally.....again,
finally some
true good earbuds made for gaming without big flaws. i was waiting these for a long time, and finally we got what we were searching for.
Before these i had a pair of
Epos GTW 270 but they had various problems, and with the latest firmware they ruined completely the battery life ( shame on EPOS ).
I waited two weeks before writing this mini-review because i wanted to be sure about the quality of the product and not rushing it
( i'm not a professional reviewer, but i'll do my best ).
My uses are for gaming 70% / movies-music-internet 30%
*** I've been using them on both PC / PlayStation 5 during these weeks ***
Pros:
- Let's start about the price. Yes they are pricey for the medium range of users which usually gets cheap stuff, but at least you get an awesome product. ( read below ). There are no perfect products out there.
- The connection is fast. They always connect to the dongle within 4 seconds, even if you pull out / pull in the dongle on another device. And they never lost the connection / signal or had sound drops / crackling noises, never happened such a thing. Perfect.
- Sound quality out of the box is pretty clean, neutral, no over-punching bass ( i didn't touch the EQ ). I'm using them on default and it's perfectly fine to me like this.
- Touch controls are on point...very responsive, you'll never miss any command. And also they are easily customizable under the Sony's software.
- Battery is on point too, i used them for about 10 hours and they still had +- 25% charge
- Sony Inzone HUB software appears to be very stable under Windows 11, easy to use and had no recognizing problems or crashes or errors to this day. The software allows to customize controls / standby mode / volume and other things.
- The latency is 30ms which is not noticeable on gaming or general purposes. They use the new Bluetooth LC3 codec
- The dongle is switchable between "PC - PS5 / Mobile" devices. But they works under "PC" mode on PS5 too without changing the switch everytime.
- They will turn off on their own after 15 minutes after you remove them from your ears. They almost immediately turn on, if you wear again....
very very VERY useful.
( this feature can be disable under the Sony Inzone HUB software ).
- About the ANC...it's a feature i'm really NOT interested. It seems decent at removing all those constant sounds in the background, like fan noises. Same as others ANC. Nothing special but useful in some situations.
- The volume level is saved within the earbuds itself, so it's not related to an external software
- They are easy to pick from the case and to put back into the case because of their shape a little "arched". Some others earbuds i tried for example were awful and slippy in the same situations.
Cons:
- Plastic case might feels cheap and the little cover are a bit brittle. Better be careful if you open/close the case a lot of time during your days.
- The confort at your ears......well that's personal. Some people will have some problems for sure, some others not. In my case, they don't slip out of my ears, but I have to insert them well (without pressing too much). Then they will stay secure.
- The case battery life could have been better. The case only ensures a 2x - 2.5x times recharge more or less, then he gets low battery.
- They have a little hiss noise in the background but is it's not annoying like someone said. it's barely noticeable only in complete silence.
They ONLY works with the dongle supplied.
In conclusion i definitely suggest them, IMO the best money i spent this year.
