how much normally drain from 100% charged airpods pro buds left out of box for 24h ?
Apple AirPods Pro And NEW AirPods Pro 2nd Gen (from 23 Sep 2022) - Impressions
- Thread starter angelom
angelom
- Apr 19, 2015
Groundhog Day.
does airpods pro improved sound quality too with new firmware??
- Jun 26, 2001
I didn’t measure anything, so nothing concrete here, however I do agree that there has been a shift in tonality, the bass is more rumbly - and treble a bit sweeter.does airpods pro improved sound quality too with new firmware??
jasonb
- Sep 14, 2010
Not sure I’m a fan of the sound changes.I didn’t measure anything, so nothing concrete here, however I do agree that there has been a shift in tonality, the bass is more rumbly - and treble a bit sweeter.
This is just another problem of TWS sets. The manufacturers can tweak the sound thru firmware and 100% of people will never all like the changes. I had to return the Cambridge Audio Melomania Touch true wireless buds because just between the time I got them and when my return period would have been over they had changed the sound of them twice.
With AirPods there is no way to stop a firmware update either. There are always people convinced that the ANC is worse or better after each update as well. With wired stuff you always know that you’re going to get.
MayaTlab
Do we know how these measurements were performed ? The only difference is to be found in the 800-2kHz range (which is the transitional range for the APP2 between the range where the classic feedback mechanism operates and the range where I believe a form of secondary feedback operates).
In terms of FR, while I am not 100% certain, I have not noticed a particularly significant difference with the latest firmware when measuring them in a 711 clone coupler from Aliexpress and with proper priming, but this represents both ideal conditions in terms of leakage and non-ideal in terms of the 711 standard being flawed, so I'm not sure how it applies to real world experiences.
In terms of ANC, subjectively speaking I now find it more stable over time. With the original firmware, it would randomly vary in performance over time, and would only go back to normal (or maybe better termed "baseline") if I turned ANC off and then on again, or if I removed the AirPods from my ears and put them back in. It seemed to improve with the previous firmware and now seems fully solved with the latest one.
how much drain box battery apple airpods pro after 24h , when charged buds and box 100.100.100%. ? does drain performance different find my network off or on?
angelom
- Apr 19, 2015
Groundhog Day...still!
heathman
- Jan 23, 2004
Asked and answered. You need to go back and read the replies.how much drain box battery apple airpods pro after 24h , when charged buds and box 100.100.100%. ? does drain performance different find my network off or on?
heathman
- Jan 23, 2004
Although I'm a fan of the APP2s overall, one thing I really dislike about them is their inability to handle wind noise when ANC is turned on. Rather than cancel the noise of the wind, they make it louder! I never had that problem with the original-generation APPs.
Progisus
My APP2 just went through the wash and dry and still work. Are they waterproof or did I just get lucky?
heathman
- Jan 23, 2004
Happy to hear it! They are designed to have some water-resistance, though you definitely got lucky.My APP2 just went through the wash and dry and still work. Are they waterproof or did I just get lucky?
I had a pair of the first-generation original AirPods (the long-stemmed ones). Those went through the laundry three times and still worked.
TooFrank
- Feb 17, 2017
why did you need to wash them 3 times?Happy to hear it! They are designed to have some water-resistance, though you definitely got lucky.
I had a pair of the first-generation original AirPods (the long-stemmed ones). Those went through the laundry three times and still worked.![]()
heathman
- Jan 23, 2004
I'm still asking myself that same question!why did you need to wash them 3 times?![]()
