HotHead
- Sep 28, 2009
doing lots of 24 bits listening over the last few days.
m903 presents the full spectrum of the 24 bits data clearer than the m902, it seems.
Thanks for posting the pic. Display doesn't really look white and doesn't appear much different than the 902.
I have the m903 on order at Sweetwater and I'd like to ask your opinion. We're planning on taking the preamp we're using out of our system and only use the m903 to serve as a preamp. Currently we're using a Conrad Johnson PV-14L tube pre into W4S SX-1000 mono amps. The CJ preamp doesn't have balanced outputs, so we don't feel we're getting the best out of the W4S amps, since the SX-1000 monos are true balanced amps. I see the m903 has balanced outputs. But does anyone know if the m903 a fully balanced unit?
Here's where I'd like an opinion - do y'all think the Grace m903 will still have some warmth and sound good when connected via TRS/XLR to the W4S mono amps, or will taking the tube pre out of the system and replacing it with the m903 be a recipe for dry analytical sound?
