Anyone get ASIO working with Xonar D2X?
Oct 6, 2008 at 8:59 AM Post #47 of 64
oh
So I guess that getting like 10-20 pS is more than fine
Oct 6, 2008 at 5:36 PM Post #54 of 64
Originally Posted by olblueyez /img/forum/go_quote.gif
Sounds like I need to install Linux and give it a try. Which version of Linux do you recommend?
You can use a Live CD - so no need to install
Just make sure it got a good player and support for FLAC or what ever you are using.
Oct 6, 2008 at 11:50 PM Post #58 of 64
mplayer is certainly the most compatible with a wide range of codecs out the box but if you prefer the foobar was of doing things then check out xmms2. You can control the player from a shell (or shell script to integrate with a program / event) on the computer's console or from another computer on the internet! If you really want to you can create your own front-end using Java, C++, Python etc...it's extensible and portable with add-ons (such as FLAC) you see. Here is a list of front-ends already available for xmms2: Clients - XMMS2
-Jonathan
