audiobomber
That is not correct. There is a definite correlation between PCM sample rate and frequency, called the Nyquist Theorem. In order for a digital ADC or DAC to correctly reproduce a frequency, the sampling rate must be 2X the frequency. In other words, a device with 44.1kHz sample rate can reproduce any frequency up to 22.05kHz, a device capable of 192kHz sample rate can reproduce any frequency up to 96kHz.The meaning of 24/192kHz or 24/96kHz does not reflect the frequency the file can process up to. I can have a 24/96kHz file that only plays music with a range of 20Hz to 20kHz. What the 96 or 192kHz meant in sampling rate is which how many times your Digital Analog Converter (DAC) or compresser is processing the file per second. If I record a live performance right now, the analog signal is processed and compressed into a digital signal (imagine a smooth curve turned into a multitude of stairs replicating a similar shape). The number of "steps" processed per second is the sampling rate. It has asolutely nothing to do with the audio frequency that you are hearing.
Personally I don't believe that frequencies higher than 20kHz have any effect on a human listener. A tweeter or headphone playing a signal higher than 20kHz is not audible IMO, but the fact that the driver can play this high means it is fast to react, and this may be a benefit in playing audible frequencies cleanly. I do believe that oversampling is beneficial, i.e. transcoding CD quality to a higher frequency, as it allows for a more gradual aliasing filter. I prefer to do this in exact multiples of the original signal to avoid interpolation. For CD (44kHz), I use 2X (88.2kHz), 176.4kHz (4X), or DSD (64X, 128X, etc).
