stymie miasma
- Sep 9, 2001
As myke suggested, have a look at www.mtbr.com. It is the HeadFi of moutain bikes!
I honestly think a mountain bike is your best bet over both a hybrid and a road bike. My take on hybrids are that they are a comfortable version of a road bike, but are generally heavier. I can't think of any advantages of buying a hyrbid over a mountain bike except that perhaps hybrids have gear ratios which are slightly more suited for commuting.
First things first. Get thee to a reputable bike store! These might be hard to find, but once you find one you are set. Some bike stores will actually take your measurements and make bike recommendations based on these. Torso length will determine whether you need a bike with a long top-tube to ensure you are not cramped in the cockpit. Alternately, this can be remedied by changing the length of your stem, but you need to be aware that this can also change the way the bike handles! THe bike store folks will help you deal with these issues
As others have said - test ride the bikes! If the store doesn't support test-riding, find another store. It is really quite amazing how the slightest variations in frame geometry can change how a bike feels and behaves.
Unless you are planning on lots of off-road riding, steer away from rear suspension. In fact, for your budget, steer away from rear-suspension full-stop. $600 will get you a bike with rear suspension, but the quality will be mediocre at best. Best spend you money on better frame and components than sinking it on rear suspension that will crap out on you within a year. Rear suspension bikes also require more servicing
While they are difficult to find, you might want to consider avoiding suspension forks as well! I am not entirely sure what US$600 will get you, but just because a bike has suspension forks does not mean they are good quality. As I said, I honestly think that it is better to spend you money on a good frame and good components (drivetrain, brakes etc) rather than superfluous gimmicks. This is especially true if you will be riding predominantly on the road. If you get bitten by the mountain biking bug, then it is quite easy to save up some money and retro-fit a pair of quality shocks at a later date. Ths way, you will not be loosing sleep worrying that your ****ty frame or drivetrain are going to crap-out on you
Manufacturers to consider:
Norco
Kona
Schwinn
Giant
GT
Gary Fisher
Bianchi
Specialized
Cannondale
Frames:
ALuminium is everywhere in mtn bikes. Most frames use 7005 series aluminium. You will also see 6061 series too. Giant uses their own prop. aluminium from Alcoa. Similarly, Cannondale used their CAD series of tubing. Good things are double-butted tubesets and extra reinforcements at the headtube junctions.
You may be lucky enough to find steel bike frame. These frames are generally more compliant that the rigid aluminium, thus giving a more 'forgiving' ride. Also, Aluminium tends to snap while steel will bend
Steel frames will rust if not looked after.
Drivetrain:
IF you can get something with a full Shimano "LX" groupset, you should have very few problems. Below "LX" is "Deore" which is also good, but I think LX will serve you better. It is quality and no-nonsense. Above LX is XT and XTR, but you may not find the increased perfromance comensurate with increased price. I personally find LX strikes a hppay balance. You may also see Sachs components which also have a good reputation. In terms of cranks, Shimano, Truvativ, Race Face are all good quality.
Brakes:
In your price bracket, V-brakes will be standard I suspect. A full shimano groupset will include LX 'V-brakes'. If not, Avid also make some good and affordable brakes. Be wary of the cheaper disc brakes that are appearing on bikes. While they look cool, they are more prone to trouble than V-brakes. If the bike does have disc brakes, make sure you read others opinions of them (www.mtbr.com). As far as mechanical disc brakes go (as opposed to hydraulic), I think only Avid and Hayes make models that are worthwhile. Remember, you can always get the dodgey disc brakes removed before you make the purchase and have them replaced with a good set of V-brakes.
Suspension Forks:
Be careful here. A lot of bikes come with some pretty ordinary suspension forks which I suspect are more trouble than they are worth. As I said earlier, it is becoming increasingly difficult to find mtn bikes WITHOUT suspension forks and manufacturers seem quite happy to include crappy forks on their cheaper bikes. If you want suspension forks, Marzocchi, RockShox (probably the 'Judy' line) and Manitou are the safest bets.
Controls:
This is where you can really tailor your bike to suit you. Change the stem length or angle. Have a long, flat stem for really stretching out. Use bar ends on your handle bars to take the pressure off your wrists and put you in a more areodynamic postion. Some seatposts have 'setback' which allows you to stretch out even more and place your weight over the back tyre. You can fiddle and upgrade here at a later date.
Tyres:
For commuting, a mtn bike with slicks will really fly along. It will alos deal better with potholes, gutters, shortcuts etc. The Continental "Town and Country" is an excellent mtn bike slick that will never wear out. If riding off road, your choice of knobbies will depend on the riding conditions.
WHOAH! Got a bit carried away there. Hope this helps you somewhat!! Main points:
1. Good bike shop - good service and support
2. Test ride ESSENTIAL
3. Spend money on a good frame. Essentially everything is replaceable and will wear out. A good frame that isn't thrashed can last you for life.
4. Dont forget a helmet!
5. Have fun, get fit and laugh at the chumps stuck in gridlock
Norco
Kona
Schwinn
Giant
GT
Gary Fisher
Bianchi
Specialized
Cannondale
Frames:
Drivetrain:
Brakes:
Suspension Forks:
Controls:
Tyres:
