Android phones and USB DACs
Aug 12, 2014 at 2:24 PM Post #5,191 of 9,526
Heh, you know, I figured, what the hell, and plugged my uDac2 without a powered hub into my Moto X a few minutes ago. Ended up working like a charm! So I do hope this is in fact just a Samsung design flaw. But people should still be careful, in general, not to try DACs that have a power hungry reputation on anything irreplaceable.
The FiiO E18 portable DAC/Amp doesn't draw much current and never hurt my S3, Note 3 or iPod Touch 5G.
When it comes to the GS3, it's Caveat Emptor
Aug 12, 2014 at 5:44 PM Post #5,192 of 9,526
Looks like Android 5.0 will have native USB audio!  Probably not overcome the 16 bit limitation (thus, still requiring UAPP for 24 bit playback), but if true, it will be nice to have all kinds of options for ROMS, notably including stock.
Could someone please explain what is "UAPP" ?
Or point me to info online somewhere ?
Thanks.
Aug 13, 2014 at 10:06 AM Post #5,194 of 9,526
Apparently Samsung messed up on the USB hardware, when a USB device draws above a certain level of current the S3 can self destruct, hence the powered Hub protects the S3.
Regarding the Galaxy S3, are there any portable dacs that can be used safely without requiring a hub/ y-cable/ juice pack? eg Hifimediy?
Any other S3 users care to comment?
Aug 13, 2014 at 10:10 AM Post #5,195 of 9,526
I can vouch for the FiiO E18, it didn't fry my S3 and I used it often. Just use an OTG cable, no Y required, it came with two flimsy short cables.
My desktop DAC, well that had the bad outcome.
Aug 13, 2014 at 11:06 AM Post #5,196 of 9,526
Behringer UCA2222 works.
Aug 13, 2014 at 11:19 AM Post #5,197 of 9,526
Ah ha, thanks for the clarification.  So for many portable DACs, it shouldn't be a problem, then.
Thanks.
Aug 13, 2014 at 12:45 PM Post #5,199 of 9,526
Fiio E07k and E17 also work well with my S3 (SGH-i747m) and are cheaper than the Fiio E18.  Just turn off USB charging on the Fiio so it doesn't suck extra juice out of your S3.  You will need to buy a USB OTG cable (Fiio L15 USB OTG cable) since it's not included in the box like the E18 does.
Aug 13, 2014 at 1:09 PM Post #5,200 of 9,526
Ordered my hifimediy sabre android dac to test with my smartphone, see if changes sound quality
Look forward to your impressions.  I've been using a Hifimediy U2 sabre (Asynch) in my desktop set up for a while and it punches massively above its weight (with a linear p/s).
Good to know. Thanks
Aug 13, 2014 at 2:47 PM Post #5,202 of 9,526
  A list of stock Android-powered devices reportedly interworking with compatible USB DAC:
stock Android device > digital USB audio out >> USB DAC >> amp >> headphones
http://goo.gl/ksoF0d
A list of USB Audio Player PRO resources (compatible USB DAC, compatible Android devices, ...):
http://www.extreamsd.com/USBAudioRecorderPRO/
A list of USB DAC reportedly interworking with the native USB audio of Android L:
Android device running on Android L > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/x3loEQ
A list of USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S3:
stock Samsung Galaxy S3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/yBKivk
A list of USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note2:
stock Galaxy Note2 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/Ga1jYw
A list of USB DAC reportedly interworking with the Android-powered smartphone Samung Galaxy S4:
stock Samsung Galaxy S4 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/dIwrqp
A list of USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note3:
stock Samsung Galaxy Note3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/7Bvkhz
A list of USB DAC reportedly interworking with the Android-powered smartphone Samung Galaxy S5:
stock Samsung Galaxy S5 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/zUjud0
A list of USB OTG cables:
http://goo.gl/4JyOe5
USB DAC descriptors:
http://goo.gl/pYJbTu
FAQ:
http://goo.gl/A4dCnP
The basics:
http://goo.gl/MCFY2x
glad to see dragonfly being supported, great news
Aug 13, 2014 at 2:48 PM Post #5,203 of 9,526
FAQ:
The basics:
thanks for this, glad to see the Dragonfly working with Samsung phones, great news
Aug 14, 2014 at 6:34 AM Post #5,204 of 9,526
Hi. I can't see any pictures online of the L15.  Does it have a regular size female socket at the non-phone end, like most OTG cables?
I see the android model has a micro usb plug.   Are you meant to connect to a usb-otg cable or directly into the phone?   (assume you would need a usb-otg cable for it to work?)
Aug 14, 2014 at 8:05 AM Post #5,205 of 9,526
you connect directly to the phone, but to get the real potential you need an amp before the earphone to sound better, this is what i read about, but mine didnt arrived yet..
