Android: Neutron Music Player
- Thread starter DrTone
WitzyZed
IYO, would poweramp benefit from following track's native sample rate?poweramp is still the best IMO
IMO, that keeps it from being "best"
Teddy230620
Hi All,
I have purchased a cayin ru7 dac. When I plug it in I get this pop up. Also
Teddy230620
If I allow I lose all my library and no other music app works. If I cancel then other music apps work but my library still disappears. I have a S20fe. I also have Neutron player installed on a lg 30v. I don't have this issue on that.
DBaldock9
Which versions of Android do the two different devices have installed? I know that Google has changed the way that apps are allowed to access storage, in the last couple of versions.
Teddy230620
Android 13 for the phone with the issue, Android 9 for the one that works.
superuser1
Did you re-add your source folders?Android 13 for the phone with the issue, Android 9 for the one that works.
superuser1
What's the difference between those two buttons?
WitzyZed
Advance track (within currently playing album)
and
Advance album (to next alphabetically)
superuser1
Therefore i would assume the difference is meaningless if one is on shuffle?Advance track (within currently playing album)
and
WitzyZed
I should correct my statement on "alphabetical" ... it instead advances to a new album based on the chosen sort order for albums (within artist, or years category, for example). But it always goes to the "next" album. If shuffle is on, it advances to a random track in the "next album".Therefore i would assume the difference is meaningless if one is on shuffle?
The buttons are labeled in the settings as "Group-switch Mode button [toggle]" in Settings->User-Interface->Playing-Now.
So if playing a user created playlist, the group-switch button advances to next listed playlist.
They are also automatically disabled if playing from the Recently Added, Recently Played, or Most Played playlists.
superuser1
Thank you very much for thatI should correct my statement on "alphabetical" ... it instead advances to a new album based on the chosen sort order for albums (within artist, or years category, for example). But it always goes to the "next" album. If shuffle is on, it advances to a random track in the "next album".
Waddiewadkins
Is it a nightmare to add folders after the first time because it is for me. Added one at the jump during set up which showed up , but now folders will add with no files.
WitzyZed
Are you on windows, android?Is it a nightmare to add folders after the first time because it is for me. Added one at the jump during set up which showed up , but now folders will add with no files.
If android, generic apk or play store apk?
