Clutz
Tells us when we're offset.
- Jun 7, 2002
It's not exactly the same, but it's close. ER4S needs about 0.0079 amps, and the ER4P needs about 0.0074.
It presents an easier load at the nominal impedance, without the impedance / frequency curve, we can't say that.
Except that they have different frequency response curves. And they have different impedance / response curves- although they are both pretty flat and displaced by about (100-27) ohms all the way across until you get to about 2.5 khz, at which point the ER4P start to get a bit easier to drive, and the ER4S start to get to be a bit harder to drive, although the ER4S relationship is not strictly monotonic.
That's true, but the opamps that they are using in their output section of various portables probably don't have the same slew-rate as a good headphone amplifier, and they're probably more current limited. And I am willing to bet that they produce less accurate wave forms.
Originally Posted by ephemere /img/forum/go_quote.gif The ER4S requires exactly the same current as the ER4P to achieve the same SPL. Higher voltage, but equal current. |
Technically speaking, the ER4S presents an easier impedance load to an amp than the ER4P under all circumstances. |
So if you like the way the ER4P sounds at position V on the volume (i.e., voltage) dial, the ER4S will sound quieter but (if anything) better at position V, regardless of the amp used. |
I think sometimes people don't realize that when you listen to headphones straight out of any piece equipment that has a headphone jack, you already are using a headphone amp. There's one built into the equipment (ipod, soundcard, etc.). If you get some other amp, you're just replacing amp A with amp B. |
