formula1
fabio-fi, jackwess and formula1 are all the same person.
- Jun 20, 2011
Teetering on the brink of doing so...
And i started this hobby with tubes, and now a solid state guy mainly. How crazy
Tips to achieve end game sound out of the h800..
1- Do the anax2.0 mod but leave out all creatology foam except for the ring around the driver...
This is because we want to keep the signature without loosing soundstage and just tame the ringing..
2-Use a true balanced amp with balanced XLR output of at least 2watts max...
The hd800 love voltage over current but need reserve power to give true bass weight...
3-Use newest cable designs that have the most surface to conductor ratio...
That means a litz type braided cable..
Stock cable is garbage and a contributor to problems as the hd800 is the most sensitive headphones to cable change that I ever tried.
There you have the "clues" to maximum performance..
Now all you need to do is find the match of components that gives you the right "flavor" you desire, which is another story altogether and will take you on a road of your choice of SS or tube route..
Sennheser's own HDVA600 and HDVD800 do very good job amping HD800s. Loving mine! BUT these amps need balanced connection!
