Speedskater
- Dec 27, 2006
Isn't Kimber TC4 a speaker cable? I was thinking RCA interconnects.
Speaker cable indeed., Moto Z, UAPP, Toneboosters and some heavily modded mdr1s! See DIY forum.Isn't Kimber TC4 a speaker cable? I was thinking RCA interconnects.
There is nothing crackpot about someone learning to perform a controlled test. Are you afraid of the outcome as to protest this much? Have you run such a test and can document the protocol and outcome? If not, then let the man be.Amirm, you *need* to stop holding so much water for crack pot nonsense. You know this well is poisoned and yet you want him to continue to confirm his bias? We already know how this is going to work out. You can't do a blind test (especially of cables) by yourself!
Ridiculous. We already know the outcome. That’s how bad this “test” is going to be. Shame on you for supporting shoddy science.There is nothing crackpot about someone learning to perform a controlled test. Are you afraid of the outcome as to protest this much? Have you run such a test and can document the protocol and outcome? If not, then let the man be.
You tried your way of insulting him left and right and it did not work. Let's see if this other method has value.
My underwriter!There is nothing crackpot about someone learning to perform a controlled test. Are you afraid of the outcome as to protest this much? Have you run such a test and can document the protocol and outcome? If not, then let the man be.
This is a bit of fun and seeming off topic but it is not.
I use this. Can any guess what for?
You know, at your persistence in abuse here I must ask you for your acknowledgment that this test is not complete. If you cannot refrain from further jabs you only confirm you are incorrigible as your like post ratio leads one to surmise.MY CONFIDENCE IN THE INTEGRITY OF THIS EXPERIMENT IS UNSHAKEN /s
Stay off My thread!
First, I need to better understand what you are doing to the cables to hide their identity. Are you covering them both with tape such that you can't tell the difference between them? I am having a hard time figuring out how that is possible.Please advise finally, as to your "blind" requirements, this I want reinforced.
All in the 1st few ops, I do not want you to bother,First, I need to better understand what you are doing to the cables to hide their identity. Are you covering them both with tape such that you can't tell the difference between them? I am having a hard time figuring out how that is possible.
My original method called for hiding the cables somehow and have someone else swap them.
I am also not clear what cable you are building. Is this for headphones, speakers, interconnect or something else?
[1] Ridiculous. We already know the outcome. That’s how bad this “test” is going to be.
[2] Shame on you for supporting shoddy science.
something very Hannibal Lecter about thisThis is a bit of fun and seeming off topic but it is not.
2. I don't think this statement is entirely fair though. In the sense that this is obviously not going to be a laboratory controlled double blind test which is peer reviewed and replicated by other scientists, this test will definitely be "shoddy science". However, that by itself doesn't totally invalidate the results, the results could constitute somewhat reliable evidence, even though it doesn't reach the standards expected of published science. On the other hand, in the sense that the test as described so far is so "shoddy" that it's unrelated to science and would not result in evidence which is even somewhat reliable, I don't see that amirm is supporting that. Both before and since your post amirm has criticised the OP's methodology and shown scepticism that the described test would be legitimately "blind".
G
