While my RKV devastates every amp that I've ever put against it, there's one big problem I have with it...hiss. The lower the impedance, the more nasty the hiss. And since the R10s have a relatively low impedance AND a very high sensitivity, I get a very nasty hiss through them. On the other hand, it's not a problem at all for Sennheisers. For the most part I've just lived with it since vocal music tends to grow loud enough to cover over the hiss, but lately since I started listening more to instrumental music, that hiss has gotten pretty distracting. So I'm looking to switch from the RKV to something a little quieter, without giving up its performance which by now I've discovered is very hard to match without getting extravagant with the price.
My price range is as below $1000 as possible, given I just killed my bank account with the Sony 9000ES, and the criteria is no background hiss with low impedance headphones, soundstage, transparency, and DETAIL. MAD DETAIL AND TREBLE. The obvious consideration for me is the Sugden Headmaster, but then what haunts me is that I just got away from a McCormack because I found it dark sounding, contrary to everybody saying it's a bright amp. Compared to the RKV, the RKV just has much more extended, clearer treble (still not detailed enough for me, but it is more extended and hearable) and a much more solid and lower bass. Given that, I'm not so sure I'd find the Sugden all that hot if it's yet another solid state amp that's just smooth as a baby's butt, and therefore not detailed enough.
The other item I've considered is the Earmax Pro, but I'm guessing it'd be a total downgrade from my RKV, and would probably still have hiss. I'm guessing if I want to avoid hiss I'd either have to go solid state or spend on the more insanely expensive tube amps such as the EAR HP4 and above.
I'd like to consider Headroom amps, but in the past I've found that their amps have rolled off highs...similar to what I heard on the McCormack. I don't know if the new lineup corrects this, but from the Texas Headfi meeting I'm getting the impression that it doesn't.
So given all this, is it the Sugden or nothing?
