ramachandra
- Jan 5, 2012
"My old Audigy2 had superb base, i don't understand what's wrong with the X-Fi.." Nothing, except the muting circuit, what the Audigy 2 probably had. Those transistors help to produce more solid bass but degrade the clarity in exchange.
"(btw, i read somewhere that the Elite Pro supplies the Opamps with +/-12V .. i know the other X-FI's supply just 5V if i'm not mistaken. ..Just a thought.)" I have not had a look on that when the Elite Pro was here. This voltages are present in the PCI socket and I don't know what was the point to not using it on the others then.
"Did the OPA1602AID (or other opamps) help at all with the base??" Very much, and do more than that. You will be surprised about the details of bass with this chip. It has clear but not hear piercing high, the mids are beautiful the string instrument are really alive.
"I'm also wondering if the opamp replacement only acts as a "hardware equalizer" " Definitely not. It is like trying a pair dirt cheap speakers sound like a good expensive pair. It just not gonna happen.
"Do you know if anyone measured the audio outputs or distortion before and after changing any opamps??" I had seen few measures on the Layman's Guide.
"designed for each other, and changing it will only introduce distortion to the sound" On the level what humans usually not able to hear, yet enough for some people to go nuts on it. You will find most OpAmps work without complications. If you get a chip what is not like the config you pull it out and put in another what it does. Simple. For example I have built the reference circuits from the datasheet of the OPA1602 and I had a problem. With any chips I have used in it I loved the sound, except with the OPA1602.
"i would really like to be sure that the improvements are real" I'm sure the PIONEER VSX-D557 is next, you just don't know yet.
"- Also, related to the main power CAP; do you know if it's connected in parallel? or in series? " I doubt it is in series. I do not have my faulty XtremeMusic to do more scratching to find it out for you. I had another card I have not mentioned above, it is suffered damage on a faulty PCI extension. I kept it for sometime to exploring then i dumped.
"did you happen to test the AD8599 OpAmp?" No.
