limpidglitch
In terms of the sound quality, AIFF = ALAC.
Even more than that, as noahbickart said, they are bit identical. No need to mince words.
Personally, I'd choose FLAC because it's more widely supported, but the OP uses Apple hardware, and Saint Steven is still trying to protect his children from FLAC, even from beyond the grave...
Geez, I can’t believe I had to join, because with all these insults nobody toke the time to simply answer a simple question without sarcasm. If you are using a Mac, instead of iTunes use the free downloadable app named XLD for your CD importing or if you wish all your Audio importing as it supports everything from Lossless to all that's in-between. People actually join these forums to gain some knowledge, project a legitimate question or simply just to help, personal feelings toward a product, company or dead guy only shows your high level of ignorance, not knowledge.![]()
Hi, just want to ask a question regarding FLAC and ALAC. I am using Mac and iPods, but recently I've been eyeing some non-Apple DAPs like the iBasso DX50, Fiio X3/X5, etc.
I'm also in the progress of converting some lower bit-rate songs in my iTunes library to either 320kpbs MP3 or lossless (ALAC). Should I be bothering with FLACs at all? I know those higher "audiophile grade" DAPs usually decode ALACs, but will it be more efficient with FLACs? Or is there no difference? Thanks in advance.
X2
There's no point in converting low bit rate. You need to re-rip at a higher rate from the start to gain anything.
ALAC does not have error handling while FLAC does.
It means, if the hard drive is corrupted/damaged and files got damages... Well, FLAC will play parts that are not damaged, while ALAC won't play ANY information.
I can't recommend ALAC as main format if you have a large collection.
http://wiki.hydrogenaudio.org/index.php?title=Lossless_comparison
See this wiki for more information.
X2
Sorry, language misunderstanding! What I mean is re-ripping my CDs to 320kpbs MP3 or ALAC.![]()
Is 7000+ songs considered a large collection?
