ChisChas
Why not try LCD-4?
Do you mean LCD-4 or LCD-i4's? I thought Audeze's were generally 'difficult' to drive/pair with a DAP? Is this an urban myth? I can't get on with IEM's so I only use full size over ears.
Why not try LCD-4?
Definitely not an urban myth. Forget about the LCD-4 and any DAP....just won't get them where they need to be. The LCDi4 sound ok from my FiiO X5 MkIII or (now sold) AK240SS, but really open up with I use the Hugo 2 (and it's 1.2-1.4W of power) to drive them.
The K812's aren't difficult to drive (the exact opposite of HD800's).
That's more of an urban myth.
K812 needs more current while HD800 needs a little bit more voltage. That's it.
On my FiiO X5 3rd Gen HD800 needs only 8 more volume points to sound as loud as K812.
If I listen to K812 at say 75 out of 120, then 83 out of 120 is pretty much the same level with HD800.
Under those circunstances, the HD800 will drain less current than K812. In other terms it will need 4 times less power than K812.
So the HD800 is still the easier load from the amplifier's perspective.
I also wanted to upgrade my desktop amp/dac (currently DF Red, superb value at £165) and when I collected my new Questyle QP2R yesterday from Audio Sanctuary, I auditioned the Hugo 2 with my K812's. I thought the pairing was amazing and ordered a black one which is arriving with the next batch in 4/5 weeks. The Hugo 2 really upgraded the sound from my K812's, very happy with what I heard using wav music from my laptop.
Ok, useful to know. Maybe a 'stoopid' question, current and voltage, do one or both these equate to the Bias & Gain settings on my new Questyle QP2R (which I collected yesterday).
If I'm not concerned about battery duration and just want the best SQ for my K812's, do I use the highest settings in the Bias & Gain options in my QP2R?
What do you like the most? The questyle or the Hugo 2? Currently I have a Chord Mojo with my K812 and can’t be happier. Extremely organic, detailed and fluid sounding combo (with Forza Audioworks Noir HPC MK2 cable and kaisertone app as player the mids are very liquid sounding AND with delicious clarity). I heartily recommend this cable and app to get that extra liquidity and transparency to the overall sound of the K812/Mojo combo). I just wonder how much better could be the sound with an Hugo2... The sound of the Chord FPG dacs is really something adictive and special.
P.S.: These headphones are really heavily underrated
Well....my first full listening session with my DAVE + K812s and yes, these headphones do scale! As amazing as they are out of my Hugo 2, things have really kicked up a few notches in transparency, sound staging and detail retrieval.
