timbukktwo
- Apr 13, 2014
Put the tiger back in his cage man, it's not worth it, lol
No kidding! I could be asking for trouble!
He might've meant it as not popular.
I agree.
How much would you pay for HD800 or Tesla T1?
Both are $500 tops, same as K812 meaning, it's about 20% better sound than K712 Pro to my ears thus worth 80% more than the street price K712 pro.
These are all good reasons; plus a few more could be added easily. At the end of the day, the informed will make their choice which headphone will overall suit there needs. For me, after all my research (irregardless of what or how others may view of my choice), I'm extremely enthusiastic with my choice of the K812's with the proper supporting cast (amplification, etc., so forth, and so on). There are quite a few other variables to consider in helping them to shine at their best, and the 'WHY' in which you use any headphone is perhaps the most important of all. If not 'perfect' (whatever that is), the Akg K812's were designed for the music professional. Do they accomplish the goal for its intended use? I think so. Could they be improved? Perhaps. I'm not quite sure why some hear the harshness in the higher frequencies, or why the distortion seems a bit much in the lower frequencies, or why the frequency response is not perfectly flat. I have ideas about the possibilities, but in the end it's the overall overwhelming complexity of variables the manufacturer has to consider in putting all this together; more than we may understand. I appreciate ideals, because that's one of the mentalities in which excellence breeds from. I also appreciate the different headphones choices that we have! However, all things considered, I'm personally very pleased with the sound quality of the K812's. I'm just not willing to waist time splitting hairs on things that are subjective, because the world's not perfect and there will always be needed improvements to be made (and in this case, I'll just 'learn' any deficiencies with the K812's; i.e.- K812's as a monitor). As is, the K812 is a fine choice, already. However, I don't necessarily place the K812's at the top, but rather among the top; especially as one of the best dynamics around that (for the most part- imho) accomplishes it's intended purpose overall.
Are all headphones 'perfect'? Of course not; not even the most 'venerable' (but come da** close- subjectively, of course). Additionally, It's funny how we (myself included, of course) all make our individual choices based on things even so subjectively biased, too. I honestly hope all of you enjoy your setup as much as I enjoy mine! Thanks for your patience regarding this post as I am not defending the K812's as much as I am defending a proper way to view the purpose in WHY anyone uses what they do, even more so.
-Best Regards
Tim
in response to some points made by @timbukktwo and @me x3 in no particular order:
- the hd800 was designed to be used as both a studio headphone monitor and reference headphone. the hd800s was released later and aimed at the audiophile market.
- golden ears doesn't have measurements for the k812. innerfidelity and headphone.com do, however.
- while variations between headphone measurements from different sources are to be expected, that doesn't make them invalid or useless. headphone measurements should be regarded as indicative rather than absolute, and i have found that they are more similar than they are different.
- i used a selection of well recorded music tracks and listened at low to moderate volume levels when i auditioned the k812 and compared it to the hd800
- it was apparent to me that the hd800 sounded cleaner, and apart from increased bass presence, i was disappointed to find that the k812 did not out-perform the hd800 in any other area to my ears
- i auditioned the k812 before tyll hertsen had published his review and measurements
i don't own the k812 or hd800. however, when i audition totl headphones and want a reference to compare them to, i invariably choose the hd800. i have no issue with folks preferring one or the other, for the choices that we make in this hobby are ultimately based on personal preference. while i recognize that we seem to have an infinite capacity to rationalise and defend our choices, that can also lead to skewed argument and selective examples.
links to k812 measurements:
http://www.innerfidelity.com/images/AKGK812SN001130.pdf
https://www.headphone.com/products/akg-k812
Assuming the K812 performs better off lower-end amplification while the HD800 performs better off higher-end amplification, I wonder at what (amp price point) the two would crossover...
To be fair, an easy to drive headphone doesn't mean it don't scale with amp. If anything, it will be very picky about the amp and source. Instead of wanting more voltage swing, it will want a bit more current and while doing so, sensitive to output impedance and noise level compared to most of the less efficient flagships out there.
K812 needs more than 4 times the power needed for HD800, it also needs lower output impedance and being a little bit more sensitive it needs slightly lower noise floor as well.
Amp matching is a whole different and quite subjective topic.
Well, true, the K812 may need meow power. But at 36 Ohm of impedance most head amps will deliver way more power to the K812 than to the HD800, that has an impedance of 300Ohm. Also, the K812 is more sensitive (110 dB/V vs 102 dB/V). In fact, with my amps in order to drive the HD800 I need to turn the volume significantly up in order to get the same sound pressure.
The main issue with the K812 from this point of view is the damping factor. Amps with a too high output impedance may not be able to drive it properly, and you get some combination of slow bass, dampened highs, collapsed scene, lack of dynamics.
Roberto
