dcstep
- Nov 27, 2007
While the 701s DEMAND a good amp with lots of power, the T.fis are happy with my iPhone. I use LossLess files on the iPhone, which are decent files, but through the Woo I was listening to vinyl and SACDs, which is much more transparent and open and dynamic. Since the review I've been listening to the UEs more and more, even at home. So, they're good with almost any source and not amplifier sensitive, but if you improve the sources and amp you'll be able to hear every detail of the improvement.
The W5000s don't need much power, BUT they're very sensitive to input impedance at the amp. The Woo has a hi/lo impedance switch and when I switched to Low the ATs improved dramatically. I'd say that the ATs are clearly the most finicky of the gang. I'll have to try them with the iPhone to see if that's an ok match. They ARE amp sensitive, I know that for certain.
Dave
Originally Posted by Audio-Omega /img/forum/go_quote.gif I suspected triple.fi was good but didn't know it could be rated above K701 and W5000. Did the amp make much difference to the sound of the triple.fi ? |
Dave
