A bit too honky|shouty in upper mids, not enough air and sparkle at the top.
Probably shouldn't comment on this until I've actually heard a pair for myself. But the upper mid thing seems to be an issue on some AKGs, like my K553. I don't see a whole lot goin on in that region on the K371 plots though. Nothing that would rival my K553's anyway...
K371 RAW LEFT:
https://www.rtings.com/headphones/1-4/graph#1671/4011
K371 RAW RIGHT:
https://www.rtings.com/headphones/1-4/graph#1671/4012
K371 COMPENSATED L & R:
https://www.rtings.com/headphones/1-4/graph#1671/3992
There are a couple small bumps in the upper midrange and low treble. The right channel in particular has a fairly well-defined peak at 3 kHz. And then a fairly precipitous drop from there into 5-6 kHz range.
I can see how these could be interpreted as somewhat shouty or mid-forward though, especially to someone who is used to IEMs, which can often be much more swollen in the bass. These are a little flat-looking overall from the mid-bass to the upper midrange. The signature is frankly not that different than alot of higher-end HPs and planar-magnetics I've looked at, which often tend to be rather flat through that whole region.
I'm also particular sensitive to sound in the 1 kHz to 2.5 kHz region though, for some reason. Maybe from listening to so many bad AM radios over the years. So sometimes even a small amount of stridency in that region can be an issue for me. And I don't necessarily mind a little bleed from the bass into the lower mids as well, as long as it's smooth and controlled. I would probably prefer that to a leaner mid to upper bass, as long as it's not too overdone.
The raw frequency plots above are only showing about a 5-6 dB rise from the midrange to the bump in the lower bass on the left channel. It's more like 8 dBs on the right channel though. An IEM would generally rise much quicker from the midrange into the bass, and could easily have triple or quadruple the amplitude in the mid-bass range as these HPs do.
If the pads aren't sealing well, that could also potentially reduce the response in the bass, making the HPs seem more mid-forward as well.
The treble response is also a little uneven on the K371. There is a fairly pronounced peak at 8-9 kHz, and the areas around that peak are maybe a bit too depressed. A headphone that's well-balanced in the treble will often (though not always) have a bit more of a peak somewhere in the middle of the upper treble at around 15-16 kHz range. These have a small peak at around 13 kHz, and are more depressed in the 15-18 kHz range. So they could be lacking a little air near the upper-most levels of the hearing range.
