up late
- Feb 19, 2013
yes, you still need a seal but you don't need deep insertion to get one. i use the medium stock tips btw.
still need a seal, even if shallow fit. I find the comply TS500 large tips to be the best, with the white (non) filters; offers the best compromise between fit, comfort, seal and the reduced treble, increased bass from the tips and seal is offset by the brighter filter. Great sound.
What filter would you recommend to use overall?
ps... (just in case you're having trouble fitting the comply's, not to patronise in any way!) to get a good fit, squeeze the comply's around the barrel of the phones, then quickly put in ear canal with a little applied force, then hold there using the tip of a finger, for about 10 seconds to allow expansion in the outer canal. Pretty comfortable like that, and they won't fall out.
I will try the large complys with the method you mentioned. How far do the complys have to be pushed onto the barrel? All the way to the end? Doing this exposes the tip of the barrel...Not sure if that would affect the sound?
i've not felt the need to try after market tips with the k3003 but i have used comply's with other earphones and found that they muffled the highs somewhat. do the comply's affect the k3003 in this way?
Guys thanks for all the suggestions i have tried everything but the fit is unberarable...They are so uncomfortable...Feel like my ears are being ripped. Sadly these are not for me.
Not so much. They tame it a little, I would say, and enhance the bass end absolutely. Well worth a try for sure! I love them.
Hi, can anyone please give me some comparison between the K3003i and the Sony XBA-Z5 and the ATH-E70 from Audio Technica if possible? I am having a chance to grab a very good deal at about the same price for either of them and I can only afford one (a second-hand k3003i, a discounted Z5 and a brand new pair of E70). Which one has more neutrality, clarity and balance? I am really obsessed with clarity and balance tbh.
Thanks, Ling.
