All Day Breakfast
I didn’t notice anything either.That’s odd, I didn’t notice anything. I might give it another listen.
Am I going crazy or did the new firmware (4C165) do something magical? I mean these souns way brighter, open and more precise/detailed. Really strong placebo…
How do you update them?
It is strange indeed and my ears could be fooling me, but I do think that they are now closer in signature to the APP (also updated to 4C165).
Hmm is that good or bad in your opinionIt is strange indeed and my ears could be fooling me, but I do think that they are now closer in signature to the APP (also updated to 4C165).
I prefer the tonality of the APP over the APM.Hmm is that good or bad in your opinion
Yes, its very unfortunate that Apple doesn't publish even basic release notes (thinking of it, they would read like "removed some out-of-spec features" anywayWell, I have established for myself several times, that it is difficult to remember how something sounds exactly. I can remember if I liked the sound of something at the time but not exact characteristics anyway. So, I am not going to debate that the signature is still the same. I do still wonder if there was changes in the algorithm for spatial sound or maybe ANC that changed - I guess we will never know
I still like both the APP and APM and I use them both a lot for different purposes.
The weight of the APM is the biggest downside of these headphones in my humble opinion as it affects comfort significantly. Why they did not go lighter in weight is beyond me.Yes, its very unfortunate that Apple doesn't publish even basic release notes (thinking of it, they would read like "removed some out-of-spec features" anyway
But they did work on ANC issues with the APP shortly after release as far as I remember, so slight audible changes are not offlimits I guess.
I got the APP just after release and for some time I was quite happy with them. After a few weeks I switched back to my 64audio CIEMs though, and then I started noticing the missing low bass on the APP, which is very important to me... so they were relegated to backup, i.e. put into my rucksack just to be taken out when I forgot other headphones or felt the need for ANC. Interestingly the fit test said everything OK initially, but recently it started complaining about fit on the right side. Will have to try out the other tips I guess...
Meanwhile I got the AP3 and I'm very happy with them. I like their sound profile more than the APP, which came as a surprise to me -- I never could listen to music with the older AP1 or AP2, but used them for phone calls. The AP3 on the other hand is not only in my pockets, but I use them voluntarily for both calls and music.
Over the last few months the APM grew on me to a point where I don't want to miss them anymore. They are really nice sounding, well done headphones. Yes, they could be a bit lighter on the head and handling could be improved (mainly that knocking of the cups when taking them out of storage, i.e. folded flat). But for a first generation over-ear they are quite impressive I think.
