RONJA MESCO
Man,you.really gave me some good perspective between the two....I have owned in many sets of cans with a smoothed out sound. I know that I'm looking for something different than that sound sig, of which, may sway me to the Elegia campHi atahanuz,
I can share my personal experiences but they include practical aspects which can't be avoided when using the headphones.
(I often listen while sitting on my desk in front of a 48" 4K TV used a a PC monitor, and I have some stuff left and right, or in drawers, etc., so I move my head whcih causes issues)
I listen mainly to metal, but secondly to various other genres (polyphony, dark ambient, neofolk-neoclassical, etc.)
and at a very low volume.
I purchased the Aeon Flow Closed (AFC) as soon as it arrived to Europe (that should be already some years ago)
and the Elegia on the first day of its release in Europe.
Where I find the AFC better and the Elegia not as good:
- This may come as a surprise, but for me the most important advantage of the AFC is that the lower part of its headband remains good looking, while the light-gray suede of the lower part of the headband of the Elegia will get a dirty coloration over use, which I find very annoying.
I had already this bad experience with the Focal Clear, so before the same happened to my Elegia, my wife solved this by knitting fabric around the headband. Headfieer xxx1313 provided a useful link where such fabric can be ordered:
https://www.ebay.com/itm/Hand-Woven...lear-Headphone-/254126561513?oid=252833263359
- The AFC feels lighter and more comfortable (if not moving the head) than the Elegia (which I find already comfortable)
- While I find the Elegia to be in the "neutral area", I think that the AFC is more neutral, especially having more of and a better distributed treble presence, the Elegia's treble feels a bit recessed and with some small dips, making it feel as being on the dark side of neutral, but still in the "neutral area" for me (treble not as recessed, not such deep dips and global tonality not as dark as Audeze's headphones).
(- also the AFC would indeed fit better those looking for smoothed musical representation, but this is not for me).
Where I find the Elegia better and the AFC not as good:
- Again this may be a surprise, but I personally find the combination of the cable + position of its connectors worse for the AFC and better for the Elegia!
The Elegia's cable is too rigid and microphonic (= mechanical transmission of sounds caused by contacts), but the cable of the AFC is quite microphonic as well and, because of the elongated shape of the headphones, the AFC's cables pass in the area of the open collar of my shirts. I usually wear shirts with an open collar (rarely closed with a tie), and the tiniest motions of my head cause frictions between the cables and the two sides of the open collar, and so excessively frequent microphonic nuisances, which I find very annoying. When I saw pictures or videos of Dan Clarke (in charge of MrSpeakers), he always wore a T-shirt, so he may not realize how much an issue this can be. This will be fine if you wear a T-shirt or a sweat shirt but this is not my case, so here in the end I surprisingly clearly prefer the Elegia.
- Average and larger motions, i.e. starting with 1-2 cm up or down or 20 degrees left or right, of my head create annoying frequent squeezy sounds with the AFC as my ears ( I am average sized) touch the left and right sides of the interior parts of the cups and these small motions make my ears rub against these inner sides of the cups. The Elegia has no such annoying issues.
(I guess this is why it is better to have round headphones. Hifiman found a further alternative with huge elongated earcups in series like the HE1000xx, these are so big that the ears don't touch them inside, solving this issue, but then the external parts of the huge elongated earcups touch the neck when moving the head, causing another issue which I find also annoying, but still less annoying than the inner frictions caused by the AFC )
- the AFC have less air inside the cups and will feel warmer more quickly than the Elegia
- Dynamics: the Elegia has (typical for Focal) excellent dynamics, making (sorry to say) the AFC sound boring for me in comparison
- Drum attacks: again the Elegia has the lead here, the AFC feels softer in comparison, especially at low volume
- Soundstage: at least at the very low volume at which I listen, the Elegia feels open with a fine soundstage, while the AFC really feels closed to me, even at very low volume
- Imaging: again much better for me with the Elegia (maybe because the AFC feels too closed?)
- Bass: I prefer the Elegia, its bass extends deeper, the bass of the AFC feels weaker, although not bad in itself
- amplification: the Elegia requires less.
This is what I can think about now, maybe something else will come to my mind.
Hoping this may be helpful,
bidn
