Anaken
- Jan 24, 2017
I do hope the delay is due to my AHMorph module request![]()
Oh they are making a tunable version?
Guys, I just collected my w900 and OMG. This is very very good. So much better then what im hearing from the Universal version. It has airier mids then the Zeus XRA and better treble extension. Has alot more Bass and it hits hard and the texture is so smooth from the DD. This can really fight the Zeus heads on. I believe it is in the same league as the Zeus. I do prefer the Zeus if the music just focuses on vocals but on an overall package, The w900 is fantastic.
Huh, that 7KHz rolloff looks rather disconcerting. I'll not be pleased if it measures the same on my rig as well.
Also, weird how the dynamic driver doesn't have the new low-pass chamber installed. Wonder if it was scrapped.
EDIT: roll-off could be due to insertion depth as well. I've experimented and seen it a lot with my ER4, there's more treble with a "shallow" fit while deep fit has tons of roll-off.
This is Universal version of W900, low-pass chamber or whatever you call that thing only going to be implemented in CIEM version, not Universal.
Based off your original FR captures, assuming before you applied the correction curve, I believe your captured upper frequencies in all measurements were slightly attenuated.
Haha, not even slightly, there's about a 10dB attenuation between 5KHz and 10KHz. Should be a non-issue after my IEC-derived compensation.
No chamber in the universal version? That sounds like it would separate the W900 into two different sound signatures altogether. Did AAW confirm this?
AAW is where I got this info from. That is a reason why I received my review sample of Universal W900 so soon, why other reviewers who requested CIEM version only getting it right now.
Hm, guess your unit could be a "V1" version of sortsIn that case the new units should be a tighter increase in bass. In theory.
Not sure what you mean, there is no V1 version. This is what AAW told to me:
"W900 is pre-designed to adapt the feature of tunable filters for all the customized version. However, for the universal version, tunable filter is not applicable because the ear piece is very compact and there is not enough space for the filters."
Just received my W900 today. I'll reserve subjective impressions for the time being, but here are my measurements (raw/compensated):
If you've been following my measuring adventures, the W900 is undeniably the highest extending IEM available today. That almost dubious claim of extension to 20,000Hz is pretty accurate, at least on my rig.
Glamour pics to come once my camera is charged and the sun is up![]()
Is yours with the AHmorph?
