DrGraceW
Sponsor: Advanced AcousticWerkes
- Jun 2, 2015
Hello!
Thanks for replying!
And thank you for your offer also.
I do agree that this is a 'generic' online custom IEMs issue, not specific to AAW.
(And options outside of online sellers are limited...)
I am OK with the (likely) need for fit adjustments.
i used to buy custom shirts and coats online: slight adjustments were often part of the process.
Some shirt seller actually offer a "test shirt" at a low price that allows to make all the adjustments before purchasing more expensive or numerous shirts, making the process less expensive for everybody.
I also wear glasses and it is usual that you need slight comfort adjustments during the first weeks.
I also wear custom ear protection, with no problem (but they are silicon, so probably demand less precise adjustments).
What I am not confident with is how this re-fit process works.
When everything seems not okay (pressure on one bone, seal different on the two ears, incorrect seal for both ears...) which suggest multiple adjustments might be necessary, I was expecting to redo prints.
Not that I was expecting you to re-shell the IEMs (I guess there are cheaper and more efficient way to proceed...and that's you industrial process anyway), but at least to have a reference.
Instead, it turned out to be a kind of guess game, with multiple email exchanges.
What is VERY time consuming (also for your team).
What I do not feel confident with at all.
Best regards
I agree that refit process can be hard to swallow at times. so whether you wish to send us a print to kick off the refit process or go with the universal fit, let us know when you have made the decision. Refer to a couple of replies above, there is a gentleman with W500 universal and it is should be the shape and fit you can expect.Personally give the geographical distance between us, a universal form will be my recommendation.
Just FYI, there is also and upgrade program for AAW IEMs, since we have actually just released new models this January and rendered W500 discontinued. If you are interested in learning more above that and take advantage of shipping the IEM to us, shoot us an email @ support@aaw.me to discuss
