May 16, 2025 at 11:49 PM Post #646 of 707
The delay to pushing out firmware updates is due to our HQ upgrading our OTA servers. I expect updates for all devices to start rolling out before the end of the month. I asked for an update and will update you once the team is back in the office on Monday.
So why can't you provide manual firmware updates? Owners wouldn't have to wait forever for this OTA server update if they could simply download and manually install firmware updates. I have wifi issues due to local conditions right now and have to use ethernet connections so part of the reason I moved on from the P1 is I can't do manual firmware updates.
May 17, 2025 at 3:57 AM Post #648 of 707
Because most users can't do that and brick their devices trying to do so.
May 17, 2025 at 7:22 AM Post #650 of 707
Most people can do it. Its a simple task.
Step 1 - copy firmware to root of internal storage.
Step 2 - install update from P1 settings
May 17, 2025 at 10:37 AM Post #652 of 707
Wrong. The first thing after copying it into the internal storage is checking the checksum to see if any errors occured during copying to not brick your device with an faulty firmware software. You do that two times. After download and after copying.
You see, that is why its done via OTA
May 17, 2025 at 11:21 AM Post #653 of 707
Certainly not a bad idea, but Android actually strictly verifies update packages before installing so it's not really necessary.
May 17, 2025 at 11:33 AM Post #654 of 707
One could think so, but AOSP contains nothing like this. There are only two official ways to upgrade AOSP/Android
- ADB and the Preboot Environment (Manual Flashing)
- OTA
https://source.android.com/docs/core/ota/virtual_ab
That means you either use OTA or you risk bricking your device (not kidding). You can implement this on your AOSP Fork on your own risk, but there is no official solution from the AOSP Developers for this.
May 17, 2025 at 11:59 AM Post #655 of 707
- OTA
Understood. Technically though, installing from the system settings is an OTA, it's just that the file is manually copied over rather than downloaded. Manual flashing from the bootloader or EDL is a different animal and much more risky. My overall point is that A&K could indeed release firmware without the OTA servers and most of us could install it... ;)
May 17, 2025 at 12:56 PM Post #656 of 707
I did miss it and reading it, i know very well why.
Both are dead flat, neither the M23 nor the P1 is colored. Tested with two Studio Reference Monitors.
The FiiO M23 gives more volume, but both have enough power to make you deaf.
So if anyone is owning a big planar wondering if this is the right DAP, don't worry, it has more than enough power to drive hard to drive planars.
Hi. Recently purchased Audeze LCD-2C. Looking for DAP with baanced port for them. Don't want slow, laggy full-fledged android DAPs for them. I watched a few video and liked the form factor, size and UI of Activo P1. Would Activo P1 be enough to drive the LCD-2C?
May 17, 2025 at 11:12 PM Post #657 of 707
Absolutely, even on 3.5mm and low gain no issues.
May 18, 2025 at 2:41 AM Post #659 of 707
Theres no way the Activo P1 will drive the LCD-2C anywhere near its capability using the 3.5mm jack on low gain. Even going balanced on high gain would be underpowered.
Are we talking about the same Headphone? This one?
https://www.audeze.com/products/lcd-2-classic
If so, I would not see why there should be an problem. I demoed it with the M11 Plus and the WM1ZM2 (which has even less power) and there were absolutely no issues, even on low gain.
I don't see a reason why the P1, having 2Vrms on SE, should have any issues whatsoever.
Unless you want to get deaf, then you need 4.4mm high gain
