TheGodfather4
- Dec 10, 2016
Hello.
When will the next firmware come out?
Thank you for reading.
Hello.
Please try Beta 2.6
https://www.dropbox.com/sh/5tfcpup1dywnc9i/AACCgWT4EjOL3ZmGlc1VE_nia?dl=0
Let us know how you go
Final update after Christmas
Just tried the new Firmware update Beta 2.6 and battery life on Wi-Fi does not drain so quickly. Also love to have the Rewind restarting the song instead of going to the previous one. Pretty much needed! keep the good work and improving it.
Another ongoing issue is that the Shuffle does not work until it's been pressed more than once.
And when browsing files inside a folder (1331 songs) the letters scroller does not work even when showing the letter (e.g.: V) it will just go down a little bit (still stuck on A or B per example). This does not happen on the ALL songs tab.
Any improvement on UX would be highly appreciated. Your product rocks (it gives you bragging rights!)
When is the output difference issue gonna be fixed? What's the point of using Android if we can't enjoy third party apps?
Andrew, Happy New Year.
I sent you the fix for app level matching ages ago. Puzzled are you still on about this? That specific reset sorts the problem 100%
PS we use Android for system control and bypass it for audio. The M2 was built to play music, not as a universal Android player.
If I am not mistaken, the fix is resetting the whole device. After that, if any digital control is touched again, there will be output difference again. So it's not good enough. Please point out if I am wrong.
OK please double check and tell me if the fix you sent me is a permanent fix, (which I don't think is). Thanks in advanceNot my understanding, but happy to double-check for you - Cheers Robert
I experienced the same issue as you Andrew - I had to re-install all my apps again and configure wifi etc,
That's not an issue, that's what happens with a full system reset. Jamie are your levels now matched between AR app and 3rd party apps?
