ThomasHK
- Aug 12, 2013
Could not resist for that Massdrop price.
Holy cow, they're practically giving them away! $100 is a great price for this DAP but I couldn't live with it after using the M0 and M6, even though it has the best sound.
Both the M0 and M6 have better battery life plus a more modern and much more responsive UI. They both have a more intuitive menu setup for enabling and connecting with Bluetooth (whether transmitting or receiving). Also, the M6 and M0 (IMO) are better suited for pockets!Would you mind elaborating on the pros and cons compared to M0 and M6? Thanks!
I'd say there are 2 things the M200 does better: it has a balanced output and to my ears, it sounds a little better than the others. Despite the M200 having a slightly better sound, I would pick the M6 or M0 all day because, for me, the overall experience matters more than any single aspect. I found the M200 frustrating every time I had to interact with it.
Thanks for the Infos.
Btw, how does exactly the BT works? I mean, It cannot act as an external wireless DAC, It merely takes sound elaborated from the wireless source and brings It to the cans, Is It?
Ok, I Will see once I receive It.
Edit: got the pic now. If i.e. my smartphone supports Aptx HD, then when It "sees" the DAP will Connect and stream to It.
I will study the issue better though, but thanks so far !
I never tried that and no longer have the device so can't test it. Hopefully someone else can chime in.Hello, does anyone (maybe @crabdog ) know if it can be used as an external Dac via the type C usb port, and if so what format and resolution can it support? thank you.
