Some customers feel a little disappointed when seeing the micro USB interface on a 4.4mm amp module in the launch event counting down poster. So here I want to explain the reason for you.
Since all the amp modules are compatible with X7/X7MKII/Q5 and the new coming amplifier&DAC, and we need to get the MFi certification for our DAC in order to decoding Apple products. While the MFi certification only open to two types of provided cables, one is USB A- Lightning, which is commonly adopted by Sony and Oppo, the other is micro-Lightning adopted by our Q5 which is a more convenient option. While the Type C-Lightning (C-L cable) is not included.
Meanwhile, owing to the master control/internal circuit design, even if we can use Type C interface to X7/X7MKII/Q5 and the new coming amplifier&DAC, the only benefit they can get is the positive and negative plug, instead of increase the transmission speed. So hope all of you can understand, physical Type C interface doesn’t mean it can support all the transmission protocols /fast charging nor bring more speedy transmission.
