I've done my portion of double blind testing to safely conclude that cables don't make a difference outside of impedance.
I gave up arguing with believers, it's like debating god's existence, to each one their own.
This is not a good method,
believe me. Unless, authentically, you have golden ears.
Just an example.
Take a piece of music "X", mastered or even mixed in one way (compression, levels, etc.,), then the same piece, mastered or even mixed in a different way (less dynamic compression...).
So the same piece of music, but objectively different. You can try it with the Rush "Power Windows" album. For instance the SHM version and the regular commercial 1997 version (said : "remastered"). And one track, let says "
The Big Money".
Then, for this to be statistically valid, you do 50 passes of each piece.
Not necessarily in a single session anyway. Take your time. It's important.
And so, blind, double blind, etc., you find the piece A-a and the piece A-b.
Good luck.
![Beer Chug :beerchug: :beerchug:](https://cdn.head-fi.org/e/headfi/beerchug.gif)
