dc-k
- Feb 19, 2012
They made high end audio equipment. Haven't you heard Femto? Check it out. Calyx says if you like Femto, M would suit you.
it's not budget end is it, the Femto
It wasn't last time when I checked the price
makes the M look a good price then...
Well, I don't expect M to sound as good as Femto, but it will have the same sound signature apparently. I read about Femto, also there was a small explanation about Calyx house sound somewhere in this thread if I remember correctly. All and all, the sound suits me fine but of course, no dap (or headphone/earphone) can rule them all. There will be people who doesn't like the presentation so it is better to make research a bit before buying an expensive device like that.
on the plus side the M will be a lot more portable and I wouldn't need a long extension cable for my daily commute...
Probably successor of M will bring more battery life as well as balanced output and probably cleaner sound with more powerful amp section. Of course, the dap will be probably quite thicker/bigger than M with those features.
That is true. , and I plan to use my own amp anyway. As good as these daps sound. And external amp does improve them. And I already own two amps so why not right. . Both my amps are balanced so I guess it's my greed playing in this lol.
Al
Size is bulky but still smaller than the hibino
The hibino is a brick. The M is thin like a iPhone. As I can put the hibino in my pNts pocket but it gets the girls looking.
