mikey8811
- May 3, 2011
I tried that errant pair of Sylvania's. One channel was a bit more prominent or maybe it was psychological because I knew they were different tubes. After a while, that didn't bother me too much. Xcalibur, you are right, the Chrome Dome GT is a very nice sounding tube - more resolving with greater inner detail than the NU Black Glass, I had in their place before. Piano notes are more vivid and more right and female vocals have that lilt to them which was engaging although not as warm as the NU's. Trumpet and sax were extended with the right amount of bite but smooth and not edgy - at least so far on the material I heard. I am going to switch the tubes around to see if the channel prominence reverses.
I will try to hunt for GTA's/ GT's to make up a pair for the "not true" Chrome Dome. Does these links have the right tubes?
http://www.ebay.com/itm/T123-Two-Sylvania-Chrome-Top-6SN7-GTA-Tubes-/120936432890?pt=Vintage_Electronics_R2&hash=item1c285f84fa
OR
http://www.ebay.com/itm/3-three-6SN7-GTA-Tubes-Sylvania-Philco-Bendix-Tested-/160826916403?pt=Vintage_Electronics_R2&hash=item257207fe33
(Seller says date codes are [size=10pt]Bendix - 312 4-52, Philco - 318 53-49, Sylvania - 448)[/size]
[size=10pt]As for the "true" Chrome Dome, do I presume that it will match a GT with the short base where the tube construction is clearly shown above the top of the base, with a heavy getter flashing although not full like the one I have, a chalky capsule shaped mica with or without teeth? See links below:[/size]
http://www.ebay.com/itm/Vintage-Sylvania-6SN7-GT-Black-Plates-Stereo-Tube-/180902550423?pt=Vintage_Electronics_R2&hash=item2a1ea1db97
http://www.ebay.com/itm/Vintage-Chrome-Sylvania-6SN7-GT-Stereo-Tube-04t-/180897299470?pt=Vintage_Electronics_R2&hash=item2a1e51bc0e
Thanks
OR
Thanks
