- Oct 6, 2013
Can anyone give me a direct comparison of what they think about the U18 w/ m20 treble vs the tia fourte? I find with using the U18 with silicone tips it can get a bit splashy/harsh but sounds great with foam tips. Was curious is the fourte brighter/splashier in the treble or more smoothed out?
And how does the DD bass compare to the 8 BAs?
Edit: I'm also using a Schiit Jotunheim + Bifrost 4490 and wondering if that may be too bright a setup for these IEMs
If you find U18 treble to be harsh, then I'm afraid you are very sensitive to lower treble. I find U18 upper mids / lower treble to be revealing but not harsh even with silicone tips. For comparison, TIA Fourte will be a little brighter, but still quite tolerable for me, though i switched to 2wire 1960 cable with Fourte. Personally, I'm sensitive to treble peaks myself, and for the reference, since I'm looking at your sig, can't tolerate Encore for too long, prefer Katana or the original K10UA over it.
So, will be a matter of personal preference and tolerance Have it paired up with neutral daps, all good. Even the pair up with more revealing Plenue 2 is fine to my ears.
