Choubdia
- Sep 19, 2016
I'm still wait for a test
I've compared the U4t/U6t/U12t for what it's worth. To me, and I'm no real audiophile, the 4 sounded great but a bit monolithic when it comes to presentation. The 6 did open up quite a lot, bringing the sound around your head and having a lot more separation and detail. The 12 was just the 6 with everything boosted, bass, separation and detail the most.Has anyone heard the A6t or A4t? How much of an upgrade (if any) is the a12t?
First thing I noticed is the comfort (first custom IEM). Even when compared to my custom ear tips, they just feel like they fit better (probably acrylic vs silicone). It might be the honeymoon period, but putting my universals back just feels off now.Looks great. Loved u12t when i had them.
Im pretty sure that a12t would be even better
Could you elaborate on how the a12t's comfort is better than custom tips? Are they just easier to get in because of the acrylic? Do they feel different once they're in?First thing I noticed is the comfort (first custom IEM). Even when compared to my custom ear tips, they just feel like they fit better (probably acrylic vs silicone). It might be the honeymoon period, but putting my universals back just feels off now.
Do you remember what the tonality differences were between the 6 and the 12? I remember seeing a graph showing the difference but I can't find it anymore.I've compared the U4t/U6t/U12t for what it's worth. To me, and I'm no real audiophile, the 4 sounded great but a bit monolithic when it comes to presentation. The 6 did open up quite a lot, bringing the sound around your head and having a lot more separation and detail. The 12 was just the 6 with everything boosted, bass, separation and detail the most.
I must say it's hard for me to get a perfect seal with universal, so I'm sure some of that got to influence my experience with the three. But the jump between the 4 and 6 is definitely noticeable, they achieve different presentation.
What specific aspects do you mean by tonality? Like I said I don't have the vocabulary people use to describe sound here, but I can try if you give me some pointersDo you remember what the tonality differences were between the 6 and the 12? I remember seeing a graph showing the difference but I can't find it anymore.
Sorry, I should have been more clear. I really mean was there any difference in the frequency response, i.e. bass, mids, treble. I know you said the 12 had more bass than the 6. Do you remember how the amount of treble and mid range compared? In particular, was the treble piercing on either? Or were the mids (lower or upper) quieter, relative to the bass, on one or the other? Thanks!What specific aspects do you mean by tonality? Like I said I don't have the vocabulary people use to describe sound here, but I can try if you give me some pointers
Can anyone that transitioned from Campfire Andromeda's to the U12T's give me some of your insight on why or why I shouldn't switch over to the U12T's? Been heavily debating.
