ekfc63
The most frustrating part is 64 Audio don’t sell a 2-pin upgrade cable with 0.75 connectors!
Yea I don’t get it. The stock cable is an abomination.The most frustrating part is 64 Audio don’t sell a 2-pin upgrade cable with 0.75 connectors!
I use the UTWS5 mmcx with a IPX -> mmcx converter. Works perfect. Only annoying thing is you cannot close the charging case with the IEMs attached. There is not enough room in the case.Can anyone comment on their experience pairing these with a true wireless Bluetooth amp? Looking at the FiiO UTWS5 2 pin.
Is it still? In the newest version currently being sold? I had thought that it was bad but they improved it.Yea I don’t get it. The stock cable is an abomination.
It's not great imo. Been using it since I bought it back about a year ago, but it's pretty microphonic and also prone to becoming a tangled mess. I really love my Zonie cable.Is it still? In the newest version currently being sold? I had thought that it was bad but they improved it.
Earlier in this thread (someone can look it up) 64 Audio said it saves room in some of their customs. The customer can specify .78 so long as that particular custom has the space.What was the rationale behind changing the connections to 0.75? Seems like a terrible move
Ive got several... fit perfectCan I just buy a 0.78 2 pin cable for the U12T ?
Currently, I email to ask 64 that can they fit 0.78mm. to a12t. They said 0.78mm. is not compatible with a12t. Is anyone had changed 0.75 to 0.78 by 64 please share.Earlier in this thread (someone can look it up) 64 Audio said it saves room in some of their customs. The customer can specify .78 so long as that particular custom has the space.
I'm using a Plussound cord with my U12t which their website says are meant for 64 Audio... and it has 0.78mm connectors. And it seems to fit. So I'm a little confused by this.Currently, I email to ask 64 that can they fit 0.78mm. to a12t. They said 0.78mm. is not compatible with a12t. Is anyone had changed 0.75 to 0.78 by 64 please share.
It is confusing. Maybe some kind of secret sauce? Maybe another email to 64 Audio and ask? I've heard they also have MMCX connectors for the Sony IER-Z1R. Why call that out, unless it's just an example, unless it's different somehow?I'm using a Plussound cord with my U12t which their website says are meant for 64 Audio... and it has 0.78mm connectors. And it seems to fit. So I'm a little confused by this.
Yeah I'm actually curious myself and plan to contact 64 or Plussound and get to the bottom of it.It is confusing. Maybe some kind of secret sauce? Maybe another email to 64 Audio and ask? I've heard they also have MMCX connectors for the Sony IER-Z1R. Why call that out, unless it's just an example, unless it's different somehow?
UIEM like U12t have 0.78mm conns... for sure. A12t = CIEM, those have mostly 0.75mm, right?I'm using a Plussound cord with my U12t which their website says are meant for 64 Audio... and it has 0.78mm connectors. And it seems to fit. So I'm a little confused by this.
