weirdmarvelous
Can anyone comment on their experience pairing these with a true wireless Bluetooth amp? Looking at the FiiO UTWS5 2 pin.
I listened to u12t as I threw 2000 bucks to buy it with the new premium balanced cable from 64 audio. My honest opinion is that this IEM is truly boring. There is nothing wrong from this IEM, but the music is just not touching anymore, not even the music I wrote myself where I should know what I am listening to. I start to think what’s wrong with the IEM, then I realized it is missing the mostly influencing frequency to our ears, exactly the dip at 2-3k in the asr review.To judge IEMs on a pure Comparison of Measurements is a joke. Most of these Guys never listen to a U12t otherwise they wouldn't compare it with 100$ IEM's
is there an all rounder IEMs that is as good as this but doesn't cost as much, maybe around $1200~$1400
Kinera Ace. Excellent build quality and has swappable terminations. But most importantly, the blue/silver/grey aesthetic matches the u12t. It should be well under your budget.Anyone have any budget cable recs for the A12t. The stock cable is one of the worst around. Budget like $100 max
I like this cable: https://www.linsoul.com/products/thieaudio-est-cable?variant=40981816049819 Soft, well made, sounds great.Anyone have any budget cable recs for the A12t. The stock cable is one of the worst around. Budget like $100 max
This is a .78 not a .75 has that effected you at all?Kinera Ace. Excellent build quality and has swappable terminations. But most importantly, the blue/silver/grey aesthetic matches the u12t. It should be well under your budget.
Seems to be oosI picked up a cheap TRN T8 16Core silver plated OCC off AliExpress for my a12t. Satisfied with it. I mistakenly ordered mine with 2-pin which due to 64 Audio’s use of 0.75 pins really limited my options.
Good grief. I'd read that 64 Audio customs had .75 connectors. I've yet to find a .75 to .78 adapter (anyone?). People say a .78 can be crammed into a .75, but I cringe.This is a .78 not a .75 has that effected you at all?
I currently am cramming it but I’d rather not tbh. I bought 2 garbage cables from Amazon in .75 to testGood grief. I'd read that 64 Audio customs had .75 connectors. I've yet to find a .75 to .78 adapter (anyone?). People say a .78 can be crammed into a .75, but I cringe.
