MrSlim
Member of the Trade
- Oct 31, 2007
This is BR777's new pride and Joy...
NIce build. He really should try the RCA 6CG7 cleartop in that amp.
interesting thread so far
I'm a fan of the CTH, although it isn't the cavalli I'd put up as the best contestant in an amp shootout in this price range. The SOHA II is a more technically refined amp for not much more money. Same "Cavalli" sound, just a bit more polished. If you get a chance to hear a SOHA II after becoming familiar with the CTH, it's an interesting contrast.
There's lots of tube opinions for the CTH and a long thread in DIY. If you're willing to spend a bit more, my favs in order:
Mullard 6DJ8 (Brit marked Mullard & IEC)
Siemans 6DJ8 (German yellow/blue box Rohr)
Bugle Boy 6DJ8 (Dutch)
They're all ~$25 tubes as singles though. Tubes really make or break the sound of this amp and it's a worthwhile investment IMO to spend on at least one expensive tube. My recommendation if you only spring for one is the Bugle boy, even though I like the mullard and siemans a bit more but for different reasons.
The best cheap upgrade for the CTH I've found is to swap out the alps volume pot for a "ebay" stepped attenuator. It makes a more positive difference than cap rolling.
i think if i upgrade i will try for something more along the lines of a stacker II, EHHA, or liquid something or other, but that will be a while im sure...
Br777 said:
thanks for the tube reccomendations.. im really enjoying this russian tube suprisingly enough, though im sure ill try many others eventually. right now all my funding is being dumped into a new dac.
I'd say don't bother yourself with the 6DJ8 in the CTH. Just go with RCA 6CG7.
Also the reason the CTH sounds better than the EF-5 is simpoly cause it is a better designed product. No steeking opamps in the signal path, a simple discrete complimentary refined diamond buffer.
Oh and its a Cavalli..need i say more.
The EHHA would be the next logical step up IMHO. As nice as the SOHA2 is, I personally prefer the CTH over it.
So for an upgrade look into a Toshiba 2232/968 based BJT version of the EHHA. Keep in mind though that the size of the EHHA is going to be huge compared to that of the CTH, and even then there is no guarantee that you will like the EHHA more.
As a child of the 70's, the picture below reminds me of that time of year when you break out the musty boxes (from attic or garage) and help your Dad put up the ornaments and lights...
