davidsh
- Oct 4, 2012
Also, you can upgrade later by getting the new k712 pads, which supposedly are the same as the annie pads.
Thank you all for those advices.
I made an [edit] to my questions : If I removed my tape deck, I could find the space for a tuve/valve headphones amp ; my budget could climb up to 400 euros --> new questions...
I that case, would a tube headphone amp be better paired with the K701 than the recommanded solid state amps ? If yes, wich models (in my budget span) would you recommand ?
I saw a second hand Little Dot MarkIII on a french forum. What would you think about that combination ? Wouldn't it be overkill for a K701 ? Would it be better than O2 ?
If I have understand this right, you can just get the 702s original pads...this way you'll have them both types of sound.
After reading a lot, I begin do doubt between K701 and HD650.
I will try to compare them in a store (unfortunatly, the K701 can't be found anymore, it will be Q701 vs HD650).
I'll also try the Micromega Myzik headphones amplifier (solid state)...
I think That SS are usualy better with K70X , for 411€ you could get the Lake People G103-S + K701 . (at Thomann.de)
I don't have any K702 now ... ANV was returned .
