DoYouRight
- May 20, 2006
I dont believe in the "sound differences" really between the two, but I do want to keep my vinyl rips in 24/96 flac from my uncles lp collection, which now takes up about 1.5 TBs of my externals. I just want the easiest and best solution for my system so when its all done and setup I can forget about it. I snagged a transit also so I will compare it and if I don't hear a difference I will return the Bel Canto.
It was mainly because it has BNC 75ohm which 1up said trumps optical. So it is not a matter of anything but usb > whatever in this case being BNC or optical spdif
EDIT: I might open up the Bel Canto and wire the output directly to the Buffalo32s board instead of using a cable from BNC - BNC. And the transit the same way on a mux board to do quick tests of each. Unless a cable would sound different.
![biggrin.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/biggrin.gif)
