One of my favorite 6SN7s!I haven't listened to a 3-hole, "1952" Sylvania "Bad Boy" in years. So I popped one in along with a pair of Tung-Sol 6AS7G (6520) and an RFT Z2c. And yes, is sounds mighty fine.
2359glenn | studio
- Thread starter Silent One
Silent One
What silence said... then nothing.
First post updated!It might be pertinent at this point to get the first post of this thread updated with relevant info about the current state of things.
Nayyte
Some tubes coming my way soon,
Toshiba 6SN7GT : https://www.ebay.com/itm/356705352353
and Chatham 6336A's : https://www.ebay.com/itm/156848811578
The 6336A purchase was not planned but when I saw them pop up, immediately I thought "just get them". Hopefully the best $94 I'll spend on tubes for the glenn.
spanyam
Oh man the 6336A from Chatham are BRILLIANT. They run super hot though, from what I saw. Sadly my set is not matched, and it had a horrible left channel drone. Hope you love yours!Some tubes coming my way soon,
And in case you don't, I'll happily buy them off you
gibosi
- Oct 18, 2012
And there is the 6528A, also from Chatham. Whereas, the Amplification Factor for the 6336 is 2.7, the AF for the 6528 about 7.0 which might be useful when using low-Z and/or inefficient headphones. Otherwise, these two tubes are about the same, with 5amp heaters.
The 6528 sounds very good in Eufonika H5M/KPCU using external heater psu.And there is the 6528A, also from Chatham. Whereas, the Amplification Factor for the 6336 is 2.7, the AF for the 6528 about 7.0 which might be useful when using low-Z and/or inefficient headphones. Otherwise, these two tubes are about the same, with 5amp heaters.
But it cost me 5 USD + almost that much in shipping...
mordy
- Aug 8, 2010
Are these 5A tubes true frame grid tubes?
Nayyte
WOW this Toshiba 6sn7gt is a workhorse! Very natural sound with lots of grip and finesse. Non-fatiguing and excellent soundstage presentation. I feel like a broken record describing tube sound at this point but this tube just doesn't have anything wrong about it, so it has everything right about it!! Dead quiet too in the Glenn.
gibosi
- Oct 18, 2012
I've never seen anything to suggest that they are. Have you?
mordy
- Aug 8, 2010
https://frank.pocnet.net/sheets/077/6/6336B.pdfI've never seen anything to suggest that they are. Have you?
Read line #6 in the description - it speaks about frame grids but I don't know what it means in this context.
Nayyte
Am I wrong in thinking that this Toshiba 6sn7GT looks very similar to a 6J5GT? Like two of their plates put in one tube; even the getter position/shape looks identical.
I've been listening to my Glenn all day with this tube haha, time for a break.
gibosi
- Oct 18, 2012
Yes, the 6J5 is basically one half of the 6SN7.
spanyam
The 6336A should work on an old 4 socket GOTL right? I tried a non matched pair a while back, and they ran ultra hot, and the left channel had a horrible drone. I'm guessing the drone is due to the non-match, but just making sure that these tubes can work
Nayyte
My understanding is that you realy have to have a Glenn with SS rectification + Lundal transformer to be ideal with 6336A. No idea about the older Glenns.
spanyam
Would love to get confirmation on this one. If a 6080 / 6as7 are the best I can do, then i'll look there instead.My understanding is that you realy have to have a Glenn with SS rectification + Lundal transformer to be ideal with 6336A. No idea about the older Glenns.
Total: 19 (members: 0, guests: 19)
